It is common to receive the SOLIDWORKS error Online license transaction failed. Please check your internet connection and try again while trying to open up SOLIDWORKS using a license that has been switched from machine activated to online licensing. This error arises when a certain temp file starts experiencing issues and needs to be reset. This article provides two methods of fixing this error.
This is the easiest method of resetting the temp file needed to clear this licensing error. If the files fail to delete, you will need to open the task manager and make sure no SOLIDWORKS processes are running in the background.
If resetting the temp file by simply deleting files from the FLEXNet folder fails to correct the problem, try downloading and resetting the temp file manually using the CommandManager.
I hope you found this tutorial helpful. Check out more solutions to common SOLIDWORKS errors below.
SOLIDWORKS Warning: A Journal File Could Not Be Created
Fix SOLIDWORKS System Resources Running Low
SOLIDWORKS Error: A Newer Version for this Application is Already Installed
Fix SOLIDWORKS Previous Toolbox Installed Blocking Upgrade Error
Quick Fix for SOLIDWORKS Install Error
SOLIDWORKS Error Message: The Sheet Format Could Not Be Located
About Cassidy Kelsch
Cassidy Kelsch is a SOLIDWORKS Technical Support Engineer and Certified SOLIDWORKS Professional based out of Salt Lake City, Utah. She earned her Bachelor’s degree in Mechanical Engineering from Utah Valley University and has over five years experience in CAD design. Cassidy joined GoEngineer in 2020.
