SOLIDWORKS PDM Duplicate File Names Check
Article by Derrick Franklin on Feb 03, 2016
In SOLIDWORKS PDM, we can enable duplicate file name checking for a vault so that users cannot create multiple files of the same file type with the same name. The duplicate file name check triggers when using the following commands:
  • Initial check in/undo check out
  • Rename
  • Recover (from deleted files)
New! Suggested Article >> SOLIDWORKS PDM Duplicate File Name Report
This is a global setting for the entire vault and applies to the specified file types stored within it. Here are the steps to enable duplicate file name checking:
How to Check for Duplicate Files Names in SOLIDWORKS PDM
  1. Log into the SOLIDWORKS PDM Administration Tool found by going to Start > All Programs > SOLIDWORKS PDM > Administration. . (Note: If you are using SOLIDWORKS PDM 2016 or older, this tool will be found by going to Start > All Programs > SOLIDWORKS Enterprise PDM.)
    SOLIDWORKS PDM Duplicate File Names Check Using Admin Tool
  2. Right-click on File Types and select Duplicate file name settings
    SOLIDWORKS PDM Duplicate File Name Settings
  3. The Duplicate File Name Check dialog is displayed. Select the option Do not allow duplicate file names in the file vault.
    Duplicate File Name Check Window SOLIDWORKS PDM
Note: You can specify only certain file types (extensions) that trigger the duplicate name check. To do this, select the option Do not allow duplicate file names of files with these extensions. Then you can enter one extension per line without any prefix. (. Or *)
Do Not Allow Duplicate File Names with these Extensions SOLIDWORKS PDM Option
More SOLIDWORKS PDM Tutorials
Locking a PDM Vault: Quick Tip
How to Move Files to a New Workflow in SOLIDWORKS PDM
SOLIDWORKS PDM - Excel Document as a Form
Troubleshooting SOLIDWORKS PDM Vault Connection Issues
SOLIDWORKS PDM Vault Clone Procedures
About Derrick Franklin
View all posts by Derrick Franklin
