GoEngineer Blog
#1 Technical Resource Worldwide – Right at Your Fingertips.
Search or Browse SOLIDWORKS & 3D Printing Product Developments, Announcements, How-To Guides, and Tutorials
Category
SIGN UP TODAY!
Get our wide array of technical resources delivered right to your inbox. Unsubscribe at any time.
GoEngineer Community
A forum created by engineers, for engineers. Join to access industry experts and connect with the engineering community.
SOLIDWORKS PDM Apr 01, 2025
SOLIDWORKS PDM administrators can configure user and group accounts in such a way as to control which users have access to the full history of versions, just the latest version or only versions that have been released as revisions. This article explains the settings involved and how to create the access a user or group should have.
SOLIDWORKS PDM Mar 28, 2025
So, you’re set up with SOLIDWORKS PDM, and you’d like to start the pass-through of data from your CAD files’ custom properties into the PDM data card (or vice versa). You can create a link between the PDM data card and your SOLIDWORKS files’ custom properties using variable mappings. In this guide, we’ll cover the process of creating that link. With SOLIDWORKS PDM variable mapping properly set up, you can take advantage of many automation features in your PDM workflow.
A sheet metal bend notch is a small cut or indentation made at the end of a bend line on a flat sheet metal part. This is designed to help press brake operators to position the material on a press brake machine for a more dialed-in approach. Mostly being used as a visual guide throughout the bending process. This tutorial explains how to create these sheet metal bend notches in SOLIDWORKS.
SOLIDWORKS PDM Mar 25, 2025
When you upgrade a SOLIDWORKS PDM vault to a new service pack or version, existing add-ins do not automatically update to the latest version. This needs to be done manually and is important because if you do not update the add-in, fixes done to the task add-in may not apply to the upgraded vault. In this article, learn how to update the convert task add-in (SWTaskAddIn) in a vault when upgrading to a new version or service pack.
DraftSight Mar 24, 2025
To create 3D objects in DraftSight, DraftSight Premium (either stand-alone Premium or Enterprise Plus) is required. This article is an introduction to basic 3D shapes (box, pyramid, wedge, cone, cylinder, sphere, and torus) and explains how to access the tools to create them.
SOLIDWORKS PDM Mar 19, 2025
SOLIDWORKS PDM is a client-server software that requires various network connections to function properly. There are numerous ways to check on those connections to ensure everything is working as it should – or to identify the problem when it’s not.
eDrawings Mar 18, 2025
This article will go over how to resolve the Application Exception: Invalid Class error that can occur when trying to launch eDrawings. You may also see it occur in PDM when clicking on a file to view the preview. The PDM preview uses eDrawings, which is why it can be seen in PDM. This error can appear simple, stating “Application Exception: Invalid Class” or lengthy with a string of other lines.
SOLIDWORKS CAD Mar 18, 2025
MySolidWorks is the official SOLIDWORKS community website. This resource is extremely valuable to SOLIDWORKS users and is available in three levels including Professional. Here's how to have a successful activation.
SOLIDWORKS Composer Mar 17, 2025
SOLIDWORKS Composer is a standalone addition to the SOLIDWORKS suite of software that lets you create graphical technical documentation alongside the design process in SOLIDWORKS and its various ancillary software. Through the use of various tools, technical documentation comes to life in a few short mouse clicks. The SOLIDWORKS Composer Digger Tool is typically used to highlight a smaller section of a larger, grander assembly brought into the software.
