SOLIDWORKS PDM Duplicate File Name Report
Article by GoEngineer on Oct 30, 2020
This guide will cover adding and using the SOLIDWORKS PDM duplicate file name report. You can download the file here. SOLIDWORKS PDM Professional comes with a tool called Report Generator, an SQL query embedded in a PDM format (.crp).
To access the Report Generator, from your local vault view, go to Tools > Report Generator.
SOLIDWORKS PDM Report Generator
Go to File > Import and browse to the file you downloaded from above.
SOLIDWORKS PDM Duplicate File Paths
Select the users you would like to allow to use the query and hit OK.
SOLIDWORKS PDM Query User Rights
Checkmark the query, select the correct vault from the droplist and then hit the play button.
Duplicate File Names in SOLIDWORKS PDM
The list of all duplicate files will be shown at the bottom. As needed, go to File > Export Results to save the list to CSV, which can be opened in Excel.
Note the Report Generator is only available for SOLIDWORKS PDM Professional and does require user permission to use.
SOLIDWORKS PDM Duplicate Files Names Report
More SOLIDWORKS PDM Tutorials
Fixing SOLIDWORKS PDM Error Message: The Program and the File Vault are of Incompatible Versions
SOLIDWORKS PDM Preserve Relative Paths Explained
SOLIDWORKS PDM Gray Folders and Local Files
SOLIDWORKS PDM - Excel Document as a Form
How to Move Files to a New Workflow in SOLIDWORKS PDM
