There can be instances where users might see gray folders or local files in their Vault View. These gray folders indicate that a local folder existed in your local Vault View but not in the SOLIDWORKS PDM vault itself.
SOLIDWORKS PDM grabs and caches copies of folders and files locally as users browse and work with files in the vault. By default, these cached files and folders will remain locally even after you log out of the Vault View so that the files don’t have to be retrieved again the next time you log in.
Gray folders show that the cached copy of a file is no longer accessible from the vault.
There are a few reasons why you could be seeing these gray folders:
Clearing the local cache removes all files that are not checked out from the working folder and are not referenced by a file that is checked out.
Administrators can change the user settings so that users are only able to see files that are part of the vault. Another option is to select the check box for Automatically delete local read-only files that are not part of the vault; this will automatically remove local copies of deleted or renamed files and folders.
Quickly Access SOLIDWORKS PDM Searches Using Keyboard Shortcuts
Removing or Deleting a Local Vault View in SOLIDWORKS PDM
Customizing SOLIDWORKS PDM Checked Out By Column
About Enrico Tolentino
Enrico graduated from California State Polytechnic University with a degree in Engineering. He is a data management specialist at GoEngineer based in Southern California. A car guy, Enrico frequents the SoCal open track days to test his limits. And, of course, his corgi's name is Rally. :)
