This article outlines the steps necessary to upgrade Web2 from 2016 SP0 or older to 2016 SP1 or newer. When upgrading Web2 from 2016 SP1 or newer, the existing application and application pool will be upgraded automatically by the SOLIDWORKS PDM Installation Manager and the following steps do not need to be performed.
The upgrade process involves manually removing the existing installation of Web2 and installing the newer version. The following steps below are taken from the SOLIDWORKS solution S-069296 and you can reference this solution from the SOLIDWORKS knowledge base on your SOLIDWORKS Customer Portal account for more information.
SOLIDWORKS PDM Web2 What's New 2020
About Jeff Jensen
Jeff is a Sr. Technical Support Engineer at GoEngineer and has been using SOLIDWORKS since 2004. He has earned a Bachelors in Design Engineering Technology from Weber State University and has used SOLIDWORKS for design and drafting in the aerospace, architectural and machine design industries.
