Customizing Web2 Search Variables
Article by Bryce Hooper on Dec 30, 2020
Web2 search capabilities are not quite as robust as a full install of SOLIDWORKS PDM.  In a web interface, we lack search cards and favorites, which stifles us down to searching for a value in the File/Folder name, Comment, and Description by default. With some tweaks to the configuration, we can free us up to search across any number of variables.
 tweak configuration to search variables
Searching by Specific Variables
If we’d like to include specific variables into the search then we can make some changes to the Web.config file located in the inetpub/wwwroot/SOLIDWORKSPDM/Web2 folder on the server hosting Web2. We’ll open this file in Notepad to make our edits. Depending on the permissions of the user logged into the server, we may need to open Notepad first with elevated permissions.  In the config file find the key “SearchDataCardVariables”. By default, the value will be “Comment|Description”.  This list can be changed to whatever PDM variable names we would like, delimiting with a vertical bar (‘|’) character.
 SOLIDWORKS PDM search specific variables
Save these changes, close the file, and restart the IIS service.  When the search is used in Web2 again it will display the list of searched fields with the modifications in the fly-out window.
 configuration tweaks to search
Searching by All Variables
If the goal is to search for a value in any location on a file it isn’t needed to add all of the variables to the search dialog.  To do this, we enable the “FreeSearch” option. To do this, launch the IIS Manager on the server hosting Web2. Navigate to the default website and 'SOLIDWORKSPDM' application.  Go to the Application Settings under ASP.NET.
 solidworks pdm searching all variables
Here look for a setting named “FreeSearch”.  Double click to open the dialog for edit and change the value to “true”.  Hit OK to the dialog and then restart the IIS services.  Now the search in Web2 will state that it is using “Free Search” and will search in all values.
 solidworks pdm free search
Creating Custom Column Sets in SOLIDWORKS PDM
Troubleshooting Workflow Revisions in SOLIDWORKS PDM
Virtual Documents in SOLIDWORKS PDM
About Bryce Hooper
View all posts by Bryce Hooper
