If you are familiar with SOLIDWORKS PDM, then you are probably aware of the ability within the software to create custom column views to display metadata in Windows Explorer. This is also possible with search results. We can create custom search results columns to display desired metadata in our search results lists.
Oftentimes, there is a need to export this information into a spreadsheet for personal use and distribution within an organization. This is very common and with SOLIDWORKS PDM, we have that capability right at our fingertips. In this article, we are going to take a look at how to create a custom search results column set and utilize it to be able to output the metadata you desire to an Excel spreadsheet.
We'll start by creating the search result columns that will include the customized properties that we desire.
We now need to modify our search card to use the custom search column set that we just created in the previous steps.
We are now ready to run a search in the vault view to see the results and export them out to an Excel spreadsheet.
I hope you found this SOLIDWORKS PDM tutorial helpful. Check out more tips and tricks listed below.
SOLIDWORKS PDM and SQL Server Performance Considerations
New SOLIDWORKS PDM Column Configurations
SOLIDWORKS PDM Preserve Relative Paths Explained
SOLIDWORKS PDM Gray Folders and Local Files
How to Update PDF Documents in SOLIDWORKS PDM with a New Revision
About Derrick Franklin
