SOLIDWORKS PDM 2021 introduced an updated interface and new PDM column configurations the end-user will see. In previous versions, administrators were only able to add additional columns to the default SOLIDWORKS PDM columns. Now all the columns can be configured and modified.
The Reset button will reset the columns to the default SOLIDWORKS PDM column set.
Localize system variables will lock the PDM System variables so that the Column Name is set to default and not customizable.
The Permissions tab can assign which user/group can see the column set. The new Preferred check box configures the default column set if the user/group has permissions to see multiple column sets.
The Column sets can now be created in other locations inside SOLIDWORKS, not just the File List in the user’s local view. Columns can be configured in the Change State, Check in, Check out, Get, Undo Check out, Contains, and Where Used.
The additional SOLIDWORKS PDM column options and configurations create more detail and nuance to the end user’s work experience while working in the vault.
Want to learn more about SOLIDWORKS PDM? Check out our YouTube channel or the additional resources listed below.
Creating Custom Column Sets in SOLIDWORKS PDM
PDM Check-In Dialog Box Columns...What Do They Mean?
Troubleshooting SOLIDWORKS PDM Vault Connection Issues
SOLIDWORKS 2022 Data Management: PDM, Manage, & Admin
About Enrico Tolentino
Enrico graduated from California State Polytechnic University with a degree in Engineering. He is a data management specialist at GoEngineer based in Southern California. A car guy, Enrico frequents the SoCal open track days to test his limits. And, of course, his corgi's name is Rally. :)
