If you're running out of disk space on the drive that you installed your archive server on, you may want to relocate the archive files to another drive or split the archive files across multiple drives. Follow the steps in this article to relocate SOLIDWORKS PDM archive files to another drive or split them up across multiple drives.
To determine the current location of the archive files, open the Windows registry on the Windows server running the SOLIDWORKS PDM Archive Server Configuration tool.
You will find keys on the right labeled ArchiveTable0 to ArchiveTable9 and ArchiveTablea to ArchiveTablef. These keys store the locations for the archive folders specific to the selected vault.
You can move the folder located at each directory path to a new drive (or separate drives) using Windows Explorer.
Once you have moved the archive folders to a new location, update the directory path value for the corresponding ‘ArchiveTable’ key in the Windows registry found in Step 2.
If the original folders remain after copying them to a new location, make sure to rename or delete them so that they are not accidentally used instead of the folders in the new location.
I hope you found this SOLIDWORKS PDM tutorial helpful. Check out more tips and tricks below.
SOLIDWORKS PDM Professional SQL Server Changes for 2022
Copying PDM Client Windows Registry in SOLIDWORKS PDM
About Jeff Jensen
Jeff is a Sr. Technical Support Engineer at GoEngineer and has been using SOLIDWORKS since 2004. He has earned a Bachelors in Design Engineering Technology from Weber State University and has used SOLIDWORKS for design and drafting in the aerospace, architectural and machine design industries.
