How to Change SOLIDWORKS Electrical User Data
Article by GoEngineer on Apr 28, 2016
This article explains how to change the user data fields in SOLIDWORKS Electrical to more relevant property names that a company might use for reporting. Rather than holding a cheat sheet that explains what User Data 1 coincides with, we can change the name of the field to a better description of the property. Each component classification gets its own user data fields that can be changed.
  1. Open SOLIDWORKS Electrical.
  2. Go to the Library Tab and select the Component Classification.
    Component Classification Options in SOLIDWORKS Electrical
  3. Select one of the component classifications and hit customize. In this example, I selected the Detectors, sensors Classification. This process can be repeated for other component classifications.
    Changing User Data in SOLIDWORKS Electrical
  4. Select the property you would like to change. The data properties will update on the right side of the panel for the selected property. In this example, the User Data 1 field was selected.
    Changing SOLIDWORKS Electrical User Data
  5. Under the Data properties, type the new description that will replace User data 1 under Label > English. In this example, “User Data 1” was replaced with Unit Price. This process can be repeated for other languages if you have other languages in the project.
    User Data and Unit Price Data in SOLIDWORKS Electrical
  6. Hit Save and OK.
For this example, when a detector, sensor symbol is used, the “User data 1” field will read “Unit Price” (shown below). This change will save confusion when using the User Data fields for reporting. Now it will be transparent what property that field is referring to when entering in data when a symbol is placed.
How to Change User Data in SOLIDWORKS Electrical
More SOLIDWORKS Electrical Tutorials
Schematics on the Road: SOLIDWORKS Electrical
Why Won't My WIres Route in SOLIDWORKS Electrical Part 1 & Part 2
SOLIDWORKS Electrical User Right Manager
SOLIDWORKS 2002 Leader Lines
SOLIDWORKS Electrical Title Block Rows and Columns
