Why Use Hex Elements in Your FEA?
Article by Shaun Bentley on Jun 14, 2021
In this article, we compare tetrahedron and hexahedron elements and show an example of why the latter can be important to implement into your FEA (Finite Element Analysis) studies.
Why Use Hex Element for FEA header
TETRAHEDRON ELEMENTS
FEA tools like SOLIDWORKS Simulation use triangle-like tetrahedron (TET4) elements to mesh models (Figure 1).
Tetrahedron Element FEA gif
Figure 1 – Left: Single TET4 element deformation; Right: 10,000 TET4 element deformation
This element type is great when users do not want to spend a lot of time meshing their models.
Tetrahedron meshing can be automated by software developers effectively and sometimes the only thing the user must be conscious of is simple: throw more elements at the problem to make it more accurate until I run out of time.
This element’s versatility and ease of use rely on the principle that all shapes can be approximated reliably as triangles.
Spherical Geometry Meshed with TET4's
Figure 2 – Left: Spherical geometry; Right: meshed with TET4’s
HEXAHEDRON ELEMENTS
Advanced FEA tools like SIMULIAworks include additional element types that give users more control over their meshes so they can optimize the solve time. One popular element is the square-like hexahedron (HEX8) element.
https://cdn.goengineer.com/hexahedron-elements-fea.gif
Figure 3 – Left: Single HEX8 element deformation; Right: 10,000 HEX8 element deformation
This element type has more stringent requirements for a couple of reasons:
  • Not all shapes can effectively be approximated with squares so mixed meshing is frequently required.
  • Users will need to identify natural surfaces on which to orient the elements.
  • More feedback may be required for more complex shapes, so for some geometries, it is not practical to use hexahedrons.
However, when this element is applied, it can be worth the additional time required to configure them.
Hexahedron vs. Tetrahedron IMPACT Example
To compare the tetrahedron to the hexahedron element, I ran a simple impact test in a few different FEA tools. I scaled the mesh size so that it took approximately 1000 seconds to solve each study. Here were my results:
Hexahedron vs Tetrahedron Element
Figure 4 – What do results look like when we scale the mesh so that each takes about 1000 seconds to solve each study?
Look carefully at the side-by-side comparison in Figure 5. What type of mesh do you think performs best?
Tetrahedron vs Hexahedron side-by-side comparison
Figure 5 – Which type of mesh seems to perform the best?
In this impact case, there seems to be a lot of numerical noise on the tetrahedron element. Even the higher order TET10 elements seem to do relatively poorly and arguably perform worse than the TET4’s. This may explain why some advanced FEA tools do not support TET10’s for impact studies.
Full details of the study can be seen here, but a quick summary is shown below:
Hex vs. Tet Summary
Figure 6 – Summary mesh and resource requirements
CONCLUSION
Hex elements offer a more efficient solution strategy for some classes of problems. Often the higher degree of local deformations occurring in an impact study might create a large benefit from using these elements.
However, for running simple static analyses, users may prefer moving quickly past the meshing phase. Tetrahedrons are a great solution for this case if deformations are not globally complex.
About Shaun Bentley
