Starting with SOLIDWORKS PDM Professional 2016 SP4, you can create a task to convert Office documents to PDF. This tutorial will outline the steps to install the task when creating a new vault and adding the task to existing vaults.
When creating a new PDM vault, you can select to install the Microsoft Office conversion task on the configuration details page as shown below.
Once the vault creation process is complete, you will see the SWPDFTaskAddin listed in the add-ins node.
You should also see the default Office to PDF task listed under the Tasks node.
In order to add the Office to PDF conversion task to existing PDM vaults, you will need to make sure the vault is at version 2016 SP4 or newer. These steps can be performed on any client install and only needs to be done once per vault.
This completes the installation of the Office to PDF conversion task. You can now configure the task to convert Office documents to PDF during workflow transitions or from a menu command.
SOLIDWORKS PDM Undo Checkout By Other Administrators
How to Change the Language in SOLIDWORKS PDM
Creating Custom Reports in SOLIDWORKS PDM
Managing SOLIDWORKS PDM Licenses
How to Update PDF Documents in SOLIDWORKS PDM with a New Revision
About Jeff Jensen
Jeff is a Sr. Technical Support Engineer at GoEngineer and has been using SOLIDWORKS since 2004. He has earned a Bachelors in Design Engineering Technology from Weber State University and has used SOLIDWORKS for design and drafting in the aerospace, architectural and machine design industries.
