In SOLIDWORKS PDM, the first step in revision management is creating a revision number. Once a revision number is created, it can then be added to a workflow to automatically set the revision.
In this example, the target state is "Approved".
We have to add the revision to this state. Double-click click on the target state and to go the revisions tab. Change Do not use a revision number to the revision number that you have previously created. Do not change any other values.
Go to the transition before the target state, in this example, it is the “Approved” transition.
Go to the Revision Numbers tab, add the revision number.
In the increment by field, enter the number 1. This will increment the revision number, one time, every time a file goes through this transition.
In the Actions tab, two actions must be set in order for the revision to translate the data card variable Inc. Revision and Set Revision. Inc revision must be listed before Set Revision, otherwise, the variable will not have the correct revision.
The final step is to test a file by sending it through the workflow multiple times. You will want to ensure that not only is the file revision incrementing, but that the data card variable is also linked correctly.
If you have any further questions about SOLIDWORKS PDM, please feel free to contact us.
SOLIDWORKS PDM - Not Selecting All References During Transitions
Ultimate Guide to PDM Permissions
