SOLIDWORKS PDM 2022 SP0 and SP1 PSA
Article by Francisco Guzman on Mar 24, 2022
The GoEngineer SOLIDWORKS Technical Support Team has received an influx of SOLIDWORKS crash cases with the SOLIDWORKS PDM add-in. If you are experiencing crashing using the PDM add-in for SOLIDWORKS and are using 2022 SP0 or SP1, this could be due to bug report SPR 1229928 (Target fix in 2022 SP2)
SPR 1229928 "2022: Check out via SOLIDWORKS add-in for part having many (hundreds) of configurations hangs minutes/hours while looping over each configuration (or crashes) - repeated calls to doc_getlist.
Workaround
  1. Open registry editor as the user (NOT run as administrator).
    1. User profile must at least have temporary permissions to edit the following registry.
  2. Browse to "HKEY_CURRENT_USER\SOFTWARE\SolidWorks\Applications\PDMWorks Enterprise\ConisioCAD\SOLIDWORKS"
  3. Create a new DWORD named "SyncLatestProp".
  4. Set value to 0
  5. Restart the client machine
Result
SOLIDWORKS PDM SPR 12299928 Workaround
If you have any questions, please reach out to Technical Support
About Francisco Guzman
View all posts by Francisco Guzman
