SOLIDWORKS Composer – Editing Camera Views While Maintaining their Orientation
Article by Camille Johnson on Jan 23, 2025
Have you ever wanted to make final edits on a SOLIDWORKS Composer Camera View, but you didn't want to backtrack and re-do the work you put into getting it exactly how you wanted it in your final product? Read on!
This guide will highlight the ability in SOLIDWORKS Composer to edit Camera Views while maintaining the orientation of assemblies and components within the view in your final product. This could include adding 2D text, a Path, a Label, or a Callout to an already-established Camera View that has been tirelessly fine-tuned to display your product in your technical documentation.
Getting Started
For this specific example, I made an assembly in SOLIDWORKS comprised of five components: a base and four different shapes that were inserted into the base as pegs (shown below).
Assembly in SOLIDWORKS Composer
Once I am satisfied with the model and after I make all the edits needed, I can import it into SOLIDWORKS Composer. This is a simple model for this example, but it will also work for more complex models and assemblies.
Camera Views
After importing the assembly model into SOLIDWORKS Composer, I generated a few Camera Views by clicking the Create View button (keyboard shortcut: CTRL+E) and renamed them with their orientation description.
Isometric Camera View Option in SOLIDWORKS Composer
In the screen capture below, the Isometric view is active and shows in the SOLIDWORKS Composer Viewport.
Editing Camera Views while Maintaining their Orientation in SOLIDWORKS Composer
Creating an Exploded View in SOLIDWORKS Composer
I did not create an Exploded View in my SOLIDWORKS model because it is just as easy to create that in SOLIDWORKS Composer.
After Translating the pegs of the assembly from the base, I have something that looks like this:
Using the Translate Option in SOLIDWORKS Composer
I can also create the exploded paths by inserting an Associative Path from Neutral via Author Tab > Path.
Create Associative Path from Neutral Option in SOLIDWORKS Composer
Yielding the following:
Example of Using Create Associate Path from Neutral in SOLIDWORKS Composer
I left the green peg out of that process on purpose, to demonstrate the next bit of functionality.
Locking/Unlocking the View & Adding Additional Collaborative Actors
I currently have the Isometric Camera View exactly as I'd like to see it in my final technical documentation. When I review the document though, I can see that I missed Associative Path from Neutral (green peg) and a few callouts. In this specific example, it would be simple just to add a new path, but models this simple may even need a different orientation to add the paths or paths may only be visible from other orientations.
Let's right-click on my Isometric View in the Views tab > Lock View.
Locking/Unlocking the View & Adding Additional Collaborative Actors in SOLIDWORKS Composer
I can reorient my model in the Viewport without affecting the current Isometric View.
Reorient SOLIDWORKS Composer Model
From there, I can add the last Associative Path from Neutral from this vantage point if needed.
Add Associative Path in SOLIDWORKS Composer
At this point, I can double-click on the Isometric (currently locked) Camera View, to re-align it.
Notice that the Associative Path from Neutral on the Green Cylinder has disappeared. Right-click on the View > Unlock View, then navigate to the Collaboration tab next to the Views tab. Expand the Paths dropdown and you will see AssociativePolylinePathFromNeutral 4 is unchecked. Check it and everything will reappear.
Model in SOLIDWORKS Composer
Collaboration Tab Options in SOLIDWORKS Composer
SOLIDWORKS Composer Editing Camera Views While Maintaining Orientation
The takeaway is that with a few simple clicks, you can preserve the work you have already done while updating to include items you might have missed or incorporate feedback on your documents. SOLIDWORKS Composer allows you to edit and update without losing work.
I hope you found this article helpful. Check out more tips and tricks listed below. Additionally, join the GoEngineer Community to participate in the conversation, create forum posts, and answer questions from other SOLIDWORKS users.
Composer Training
Want to take your Composer skills to the next level? Our SOLIDWORKS Composer training course covers how to use the software to create 2D and 3D output from CAD design data.
SOLIDWORKS Composer Training Available from GoEngineer
SOLIDWORKS Decals Not Showing in Composer
Tips for Protecting SOLIDWORKS Composer Files
SOLIDWORKS Composer: Solving Missing Actors
SOLIDWORKS Composer: Setting Up Actors for Kinematic Relationships
Re-Aligning Textures in SOLIDWORKS Composer
VIEW ALL SOLIDWORKS COMPOSER TUTORIALS
About Camille Johnson
Camille Johnson is a Certified SOLIDWORKS Expert based out of Atlanta, Georgia. She earned her Bachelor of Science in Biomedical Engineering and Master of Science in Mechanical Engineering from the Georgia Institute of Technology in Atlanta, Georgia. She has been with GoEngineer, helping customers with SOLIDWORKS, SOLIDWORKS Visualize, SOLIDWORKS Composer, and DraftSight needs since January of 2024.
View all posts by Camille Johnson
