GoEngineer Blog
#1 Technical Resource Worldwide – Right at Your Fingertips.
Search or Browse SOLIDWORKS & 3D Printing Product Developments, Announcements, How-To Guides, and Tutorials
Category
SIGN UP TODAY!
Get our wide array of technical resources delivered right to your inbox. Unsubscribe at any time.
GoEngineer Community
A forum created by engineers, for engineers. Join to access industry experts and connect with the engineering community.
Imagine it’s a hot summer day, and you’re driving down the freeway when your AC goes out – what to do? Roll down the windows to get some airflow, that’s what. But now, with all the air blowing around in the cabin, how does this affect gas mileage? When it comes to aerodynamics, seemingly small changes can have a significant effect on drag and fuel efficiency. In this article, SOLIDWORKS Flow Simulation will help determine how different window configurations on a generic sedan (fully closed, partially open, or fully open, etc.)  By comparing these scenarios, we can gain insights into how variations in drag on your car can translate directly into fuel consumption differences.
DriveWorks Feb 05, 2025
DriveWorks Data Management is a component of DriveWorks Pro that allows control over the data stored in a DriveWorks shared or individual group. With Data Management, users can directly control project files, CAD files, specifications, etc., which are being accessed by the other DriveWorks applications such as Administrator, Live, Autopilot, and User.
SOLIDWORKS Composer Feb 04, 2025
If you plan to move your SOLIDWORKS Composer license to a different machine, you must deactivate it. It is also best practice to deactivate Composer—and any other SOLIDWORKS products—prior to major changes to your computer like replacing the hard drive.
SOLIDWORKS PDM Feb 03, 2025
SOLIDWORKS PDM Professional is a powerful document management tool. Collaboration, version control, revision control, change history, and access control are just some of the many features of PDM. Some of these features can be automated by Dispatch, an add-in provided with PDM. Automation can also be achieved by API written in C++, C#, or Visual Basic. However, Dispatch and in-house API can have their challenges. If the out of the box options can be so problematic, then there has to be a better solution. Enter GoExpress.
SOLIDWORKS animations can be useful for showing movement in your assemblies. Sometimes, you’ll want more precise movement than you’d otherwise find by dragging your parts. As a quick refresher, let’s go over the basic steps to set up an animation.
SOLIDWORKS CAD Jan 30, 2025
The foremost item to note about this migration is that the license software itself syncs with the SolidWorks Activation Server and directly checks the license out from the system. The process requires a transfer of the license off the old server back to the SolidWorks Activation Server before the new server will be able to be activated with the SolidWorks Activation Server and allowed to administer licenses to client machines.
Abaqus Jan 29, 2025
No matter how intuitive and robust a program is, it often takes time for new users to familiarize themselves with it and develop techniques to maximize their efficiency. So in this article, we'll share some Abaqus tips and tricks to shorten the learning curve, speed up your analyses, and get the most out of your new FEA software.
Reverse Engineering Jan 24, 2025
SOLIDWORKS is an impressive 3D modeling software widely used in the engineering and design industry. While it excels in creating 3D models from scratch, there are times when you need to work with existing physical objects. In these cases, 3D scanning technology and software come to the rescue. In this article, we'll show how to 3D scan inside SOLIDWORKS using the Geomagic for SOLIDWORKS add-in.
SOLIDWORKS Composer Jan 23, 2025
This guide will highlight the ability in SOLIDWORKS Composer to edit Camera Views while maintaining the orientation of assemblies and components within the view in your final product. This could include adding 2D text, a Path, a Label, or a Callout to an already-established Camera View that has been tirelessly fine-tuned to display your product in your technical documentation.
