3DEXPERIENCE Smart Manufacturing 2024 - What's New
Article by Don Glaske on Nov 06, 2023
By leveraging the 3DEXPERIENCE Smart Manufacturing 2024 tools, you can put your company’s future in the driver’s seat by having real-time communication between the shop and the engineering department, which is critical to getting parts out the door on time. Communication across a company is important, but it's important to ensure everyone has access to make decisions based on the same data.
What's New for 3DEXPERIENCE Smart Manufacturing 2024
The NC Shop Floor Programmer allows users to create and simulate 2.5 & 3-Axis NC programs in an offline virtual environment for early set-up validation and qualification to mitigate errors and rework and reduce NC programming time.
The virtual manufacturing cell keeps associativity with design, ensuring concurrent engineering with a Single Source of Truth for all shop floor resources and NC processes to eliminate communication errors.
Added functionalities include:
  • Probing
  • 3+2 Programming
  • Deburring
  • WireEDM Programming
  • Nesting
  • Laser/Waterjet Cutting Programming
Note: The above items are included with all 3DEXPERIENCE NC Programming roles.
3DEXPERIENCE Smart Manufacturing 2024 NC Shop Floor Tools
Validating Parts for Manufacturability
All 3DEXPERIENCE NC Programmer roles include the Manufacturability Check app. In SOLIDWORKS, this app is comparable to the Design for Manufacturability tool known as DFMXpress.
3DEXPERIENCE Manufacturability Check Icon Check Processes and Check with Resources Icons 3DEXPERIENCE
Manufacturability Check allows users to validate parts in a virtual offline 3D environment on a CNC machine to check for part manufacturability based on company-specific design standards (e.g., standard hole sizes, depths, and depth of flat-bottomed holes).
3DEXPERIENCE 2024 Smart Manufacturing Check Process for Additive and Subtractive Process
Manufacturing parameters can be set to analyze both additive and subtractive processes for quoting and process planning on the shop floor.
Results Panel for Additive and Subtractive Process in 3DEXPERIENCE 2024 Manufacturing Tools
Spot an issue? Use the 3D Markup feature to send details to the engineer. Quickly insert text and graphics to help convey the issue.
Snapshots can also be created of the 3D model and quickly sent out for review all while remaining in the 3DEXPERINCE Platform.
Create Markups and Leave Comments in 3DEXPERIENCE Manufacturing 2024
Once a part is finalized, replace the existing part with the new revision without the need to open and place the part again.
Replace by Existing 3DEXPERIENCE Smart Manufacturing 2024
Finally, run the revised part through the manufacturability check one last time for verification before it's sent off for manufacturing.
3DEXPERIENCE DELMIA Manufacturability Check
3DEXPERIENCE Shop Floor Programmer
Since a part is validated for manufacturing in a digital twin virtual environment, when it is time to start programming the part, just open the same manufacturing cell already created in the 3DEXPERIENCE Shop Floor Programmer to begin programming the part.
The machining cell was created from a machining cell template which includes tooling and fixtures, eliminating the time-consuming task of loading tools and placing vises.
3DEXPERIENCE DELMIA 2024 Shop Floor Machining
With easy-to-follow pop-ups and the Machining Wizard, the Shop Floor Programmer role for machining takes a lot of the guesswork out of programming parts.
All toolpaths are displayed using the kinematics of your actual machine. 3DEXPERIENCE creates a virtual twin that accurately shows what will happen on the manufacturing floor.
What's New 3DEXPERIENCE Smart Manufacturing 2024
3DXEPERIENCE Robot Programmer Essentials
For many reasons, industrial robotics are becoming a standard in manufacturing facilities. Although the use of industrial robots has become more common, programming them can still be a challenge.
The 3DXEPERIENCE Robot Programmer Essentials role gives users the power to easily program, simulate, and validate multiple brands of robotic arms for machine tending, arc welding, pick & place, cutting, and adhesives applications.
3DEXPERIENCE Robot Programming Essentials Role 2024 What's New
3DEXPERIENCE Robot Programmer
Applications:
  • Arc Welding
  • Adhesives
  • Cutting
  • Machine Tending
  • Pick & Place
  • Offline Programming with Robot Translators
Equipment, Tooling, and Workcell Layout:
  • Kinematics for End Effectors, Clamps, & Fixtures
  • Positioning Tables
  • Gantries & Rails
  • Robot Libraries
Because programming is performed offline, your equipment can stay up and running while you program, simulate, and validate new tasks.
3DEXPERIENCE Robot Programmer lets users easily place robotic arms by showing possible locations based on the robot’s reachability based on the green grid squares.
Robot Programming Essentials Role 3DEXPERIENCE 2024
Additionally, use manufacturing cells to create a virtual twin of a factory floor.
3DEXPERIENCE Factory Simulation Engineer
With 3DEXPERIENCE Factory Simulation Engineer, users can simulate and optimize material flow and resources using a virtual twin of any facility.
What's New Smart Manufacturing 3DEXPERIENCE 2024
Applications:
  • Production system throughput
  • Perform "as-Is" and "What-If" analysis
  • Bottle Neck identification
  • Resource KPI monitoring
  • Inventory Tracking (WIP) upon production rate
  • Descrete Event Simulation with random events support (failure, missing parts, cycle time) to simulate an hour, a day, a week, or months
  • Push Pull-Mode Support capabilities
  • Calendar Shift, Lot, Sequence Schedule
  • AGV Simulation / Human Path generation / Robotics integration
  • Create Machine Resources and add kinematics
  • Manufacturing Resources library
  • ONE Single 3DEXPERIENCE Environment
    With an accurate, scalable representation of a facility, users can optimize layouts, plan for expansion, and create flow studies to ensure the most efficient production environment.
    Shop Floor Machining What's New 3DEXPERIENCE 2024
    From programming CNC machines and robots to creating the optimum production floor layout, 3DEXPERIENCE Works Manufacturing Solutions are ready to help you expand your horizons. With the 3DEXPERIENCE Manufacturing Portfolio inside of 3DEXPERIENCE Works, data is collected throughout the process. From analyzing the part to shipping it out the door, all stakeholders have real-time visibility to make fast and accurate decisions.
    On-Demand Launch Event
    0:02
    0:00
    WATCH THE ON-DEMAND LAUNCH EVENT
    Want more SOLIDWORKS 2024? Register now to join our virtual launch event on-demand to see everything new in the latest release. Our experts walk you through each enhancement across the entire SOLIDWORKS portfolio including Simulation, CAM, PDM, Electrial, 3DEXPERIENCE, and more.
    More What's New 2024 Content
    SOLIDWORKS CAM 2024: Dynamic Highlight, Output Options, Tool Select Filter, & More
    SOLIDWORKS Flow Simulation 2024 - What's New
    What's New SOLIDWORKS 2024 Structure Systems
    New in SOLIDWORKS Visualize 2024: Importing, Appearances, Interactive Images, & More
    SOLIDWORKS 2024 STEP File Import Filter
    VIEW ALL ARTICLES
