DriveWorks Pro Admin Stages Explained – User Interface
Article by GoEngineer on May 14, 2018
In this article in our series on the stages of the DriveWorks Professional Administrator interface, we go through the three areas, Form Navigation, Form Design, and Form Messages.
DriveWorks Professional Form Navigation
Figure #1 – DriveWorks Professional Administrator Dialog
Form Navigation:
By using Decisions, you can selectively decide whether to show specific forms based on values the user has already entered. A “Details” form is created by default and automatically linked into the navigation (see Figure #2).
Figure #2 – Stage 2: User Interface – Form Navigation
In this section, you can create forms, add decisions between forms for navigation, build rules, rename, delete, and use the Overview window if your form layout is too large for your screen.
The “Add Form” button allows you to create a blank form (see Figure #3).
DriveWorks professional Add Blank Form
Figure #3 – Stage 2: User Interface – Add Blank Form
The “Add Form” pull-down menu allows you to insert a template instead of a blank form (see Figure #4).
DriveWorks Professional Add Form Template
Figure #4 – Stage 2: User Interface – Add Form Template
Selecting “Add Form Template” opens the following dialog (see Figure #5) which allows you to select from a collection of built-in templates.
DriveWorks Professional New Form Template Dialog
Figure #5 – Stage 2: User Interface – New Form Template Dialog
In both dialogs “Add Form” & “Add Form Template”, you have to enter a name for the new form. The name cannot be the same as another form or contain any non-alphanumeric characters other than an underscore.
The “Add Decision” button allows you provide some logic into the form navigation similar to how an IF/THEN statement works (see Figure #6).
DriveWorks Professional Add Decision
Figure #6 – Stage 2: User Interface – Add Decision
Once you provide a name for the decision, next step is to drag the True/False points in the decision to the appropriate form (see Figure #7).
DriveWorks Professional User Intercface Add Decision
Figure #7 – Stage 2: User Interface – Add Decision
Form Design:
The Form Designer task allows you to create the interface for the users to work with. There is a large number of controls and flexibility in how the form interacts and shows information.
The following screenshot (see Figure #8) will show the areas of the form designer, but the specifics of the controls including adding, moving, aligning, and setting up will be covered in its own document.
DriveWorks Professional form Design Areas
Figure #8 – Stage 2: User Interface – Form Design Areas
Form Messages:
The Form Messages task allows you to create messages that can be used with controls to indicate when users have typed in values which are invalid and provide details on the correct values required (see Figure #9).
You can add, delete, and build rules for each message. When using these with controls, just make sure that you double-check the message number as this is how you associate the message with the control.
DriveWorks Professional Form Messag
Figure #9 – Stage 2: User Interface – Form Messages
Please see the following links for more information on this stage and the tasks within it.
Form Navigation:
http://docs.driveworkspro.com/Topic/ProjectEditorFormNavigation
Form Design:
http://docs.driveworkspro.com/Topic/ProjectEditorFormDesign
Form Messages:
http://docs.driveworkspro.com/Topic/ProjectEditorFormMessages
