Successfully upgrading SOLIDWORKS PDM yourself takes planning. The process is simple enough, but it is essential to review all the steps and verify that everything is ready before starting the upgrade. This guide outlines the process to plan and complete the upgrade, with links to detailed instructions in each step.
Please review these articles and their instructions long before you plan your upgrade. You may need to upgrade your server operating system or your SQL Server version, or you may decide to create a new PDM server. It is best to review the prerequisites for the new SOLIDWORKS PDM version to verify that your server and SQL versions meet the new requirements and allow time for upgrades as needed.
PDM Clients MUST match the major version. If the server version is 2023, then the client must also be on 2023. The service packs don’t need to match. A client at 2023 sp3 will work fine with a server at 2023 sp0.
Once the PDM server has been upgraded, the clients won’t be able to connect to PDM until they are upgraded.
Before the upgrade date:
On the day of the upgrade:
This guide will provide links to documents for complex steps. It is advised to also review the documentation provided by SOLIDWORKS. Below is a link to the SOLIDWORKS Administration guides:
Note: You can select the desired version from the drop-down at the top.
For SOLIDWORKS PDM, you might be interested in:
For upgrading PDM, please refer to Chapter 11, Upgrading SOLIDWORKS PDM.
Below are links to the system requirements from SOLIDWORKS. Use these to verify your system matches the requirements of the version you are upgrading to.
SOLIDWORKS PDM 2021 is the last version of PDM that can use SQL Server 2014. SQL Server 2014 is the last SQL Server that was supplied by SOLIDWORKS.
So, if you are currently using SQL Server 2014 and you want to upgrade to PDM 2022 or later, then you MUST upgrade your SQL Server.
SOLIDWORKS PDM Professional requires SQL Server Standard or Enterprise, which must be purchased by your company. Plan on this expense when planning the upgrade.
SOLIDWORKS PDM Standard uses SQL Server Express, which is free to download from the internet. You will still need to upgrade, but you can download the upgrade over the internet or use the version in the full installation file set.
SQL Server 2019 requires Cumulative Update 4 or later. Cumulative Update is the SQL equivalent of a service pack. Please download the latest from the internet. Click the link below to the Microsoft website for this: SQL Server 2019 latest Cumulative Update.
Start with the SOLIDWORKS Installation Manager and download the file set from SOLIDWORKS, or download the file set from (linked below).
Note: Use 7-zip to unzip the package. Windows unzip will block the .html files, and the installer won’t work!
Upgrade the SolidNetwork License Manager (SNL) Server first. The licenses are backward compatible with the older releases. This way, your licenses are ready to be acquired by your newly upgraded PDM client and SOLIDWORKS CAD but can still be used by the current version clients until you’re ready:
Pull up Services by typing “services” in the Windows search application.
Select Services from the offerings.
Find the SOLIDWORKS PDM Archive Server service.
Right-click it and choose Stop the service or choose Stop the service in the top left.
In the article below, follow the steps to create a database backup manually.
There are minor differences in upgrading the PDM server software between PDM Professional and PDM Standard. To be clear on the process, we have an article for each version of PDM.
The vault database must also be upgraded to the new version. Failure to do so will result in in the message The client and server are of incompatible versions with a listing of the two versions.
On the licensing server, start the SolidNetwork License Manager Server.
Version 31.3 is 2023 SP3.
Select About to see the installed version.
Select License Usage and then the SOLIDWORKS PDM version that you have.
Total licenses is the total number of licenses active on this license server.
Go to the vault view on the archive server and log into it. Verify that files can be retrieved and checked out/in. If these actions work here on the server, then it is time to upgrade the clients.
This is done when upgrading the first PDM client that is also running SOLIDWORKS. Follow the directions below to upgrade Toolbox:
You are now ready to finish upgrading all SOLIDWORKS users.
Here is an article for upgrading a PDM Client that does not use SOLIDWORKS.
This article explains how to update the convert task add-in (SWTaskAddIn) in a vault when upgrading to a new version or service pack.
This concludes how to upgrade SOLIDWORKS PDM yourself. Learn more about SOLIDWORKS PDM by checking out the tutorials and tips listed below.
How to Search for Variables That Have Been Left Blank in SOLIDWORKS PDM Data Cards
SOLIDWORKS PDM: Dynamic Reporting Using Excel
Using and Exporting BOMs from Inside SOLIDWORKS PDM
SOLIDWORKS PDM: Fix SOLIDWORKS File Associations
About Jim Ward
Jim Ward is a part of the GoEngineer SOLIDWORKS PDM Support team. He has a BSME from CSU, Chico. He worked in design for about 12 years then moved into a SOLIDWORKS support role. The last several years have been focused on SOLIDWORKS PDM Professional (formerly Enterprise PDM).
