So, it is time to upgrade your SOLIDWORKS PDM and SOLIDWORKS. Along with SOLIDWORKS, you will need to upgrade the Toolbox. In your case, your company has multiple clients to upgrade. Prior to SOLIDWORKS PDM, you had the Toolbox in a shared location on your network. In this situation, the first client to be upgraded would also upgrade the Toolbox in the shared location. As other clients are upgraded, they will begin to upgrade Toolbox, realize it has already been upgraded so will skip the Toolbox upgrade as it is unnecessary.
But, your Toolbox is now inside of your PDM vault and it is managed by SOLIDWORKS PDM. Again, you have multiple clients that you will need to upgrade. What is the best method of upgrading Toolbox now that it is in SOLIDWORKS PDM?
With Toolbox being inside of the PDM vault there are some items to consider:
Ever since SOLIDWORKS 2016 the PDM client can be installed as part of the SOLIDWORKS install and is the recommended way to install the PDM client. To do a client install you can use the downloaded installation file set or you can create an Admin Image and do the installations from that. In either case, the first client install is used to update the Toolbox and it must be done using the full installation file set – not the admin image.
When SOLIDWORKS is installed it has to be installed with it pointing to a Toolbox. If you don’t do this, then Toolbox won’t be an option in the finished SOLIDWORKS install. Point to the Toolbox location inside of the PDM vault.
So, how do you recover if you received this document too late and your SOLIDWORKS/Toolbox is broken? How do you fix it?
There are two methods that can be used after the upgrade is complete. This first method is preferred because it will make all changes to the Toolbox to get it to the current version. Any new files will be added.
If the above doesn’t fix the problem then you need to upgrade the Toolbox database only. This isn’t as desirable as the first method as it only updates the database. But, that is enough so that SOLIDWORKS will be able to use the Toolbox again. In order to use this method, you must use a utility that is provided by SOLIDWORKS.
You can now open SOLIDWORKS and have it reference this Toolbox. Be certain all Toolbox files are checked into the vault. Other SOLIDWORKS users will need to download the latest version of the database.
Solidworks Toolbox Library Setup and Utilization
Enabling the SOLIDWORKS PDM Administration Tool Shortcut
Locking a SOLIDWORKS PDM Vault Quick Tip
