Upgrade a PDM Client without SOLIDWORKS
Article by Jim Ward on Nov 29, 2023
This article covers upgrading a SOLIDWORKS PDM Client that does not use SOLIDWORKS 3D modeling. The PDM Client must match the major version that is on the server, but the service pack can be different. If the server has PDM 2022 SP2 installed, then the client can be any service pack of 2022. However, the client will not connect to the server if it is updated to PDM 2023 while the server is still version 2022.
The PDM server is usually upgraded to the next major version, and then the SOLIDWORKS clients are upgraded.
Before the Upgrade
  • Check in all files.
    • This is the safest approach, as the files are copied to the server.
    • As long as the local view is not deleted, the checked-out files can be checked in after the upgrade.
SOLIDWORKS Installation Manager
Always run installations and upgrades with the SOLIDWORKS Installation Manager. The reason is that SOLIDWORKS Installation Manager will check for prerequisites and install them as needed. Failure to use SOLIDWORKS Installation Manager may result in PDM not working as the required prerequisites have not been installed.
Run SOLIDWORKS Installation Manager
At the root of the installation folder, run "setup.exe"
At the top of the dialog, verify it is the SOLIDWORKS [version] Installation Manager
Select Install on this computer.
Select Next
SOLIDWORKS Installation Manager Option Install on this Computer
Uncheck SOLIDWORKS. Since we aren't installing SOLIDWORKS, we don’t need a serial number.
Select Next
Uncheck SOLIDWORKS
There is a warning about not using a serial number.
Select OK.
SOLIDWORKS Installation Manager Warning: Are you sure you want to remove the SOLIDWORKS serial number from the computer
Another warning appears that you will be limited to products that don’t need a serial number.
Select OK
SOLIDWORKS Installation Manager Warning: You have not entered a serial number.
There is a warning that the client version of PDM must match the server version of PDM. This is fine, as we are upgrading in response to a server upgrade.
Select Next.
SOLIDWORKS System Check Warnings: A previous major version of SOLIDWORKS PDM Client was detected.
Select to upgrade your current version of SOLIDWORKS.
Select Next.
SOLIDWORKS Installation Option to Upgrade SOLIDWORKS to Different Version
The next screen is to verify the components to install. Since this is an upgrade, everything should be selected.
Verify that eDrawings and SOLIDWORKS PDM Client are selected.
Select Next.
eDrawings and SOLIDWORKS PDM Client Selection
Since this is an upgrade, the PDM Options don’t need to be changed.
Accept the SOLIDWORKS terms and then click Install Now.
Upgrade a PDM Client Without SOLIDWORKS
SOLIDWORKS PDM always uses network licensing. Verify the licensing server is correct.
Select OK.
SOLIDWORKS Installation Manager Specify the port number and server name for the SolidNetWork License Server.
The SOLIDWORKS upgrade will start to run.
Installing Selected SOLIDWORKS Products
Once complete, choose your participation in the SOLIDWORKS Customer Experience Improvement Program.
Select Finish.
Installation is Complete SOLIDWORKS Installation Manager
Remember to reboot your computer after the installation.
I hope you found this article for upgrading a PDM Client without SOLIDWORKS helpful. Learn more about SOLIDWORKS PDM by checking out our full list of articles here. Additionally, join the GoEngineer Community to participate in the conversation, create forum posts, and answer questions from other SOLIDWORKS users.
About Jim Ward
Jim Ward is a part of the GoEngineer SOLIDWORKS PDM Support team. He has a BSME from CSU, Chico. He worked in design for about 12 years then moved into a SOLIDWORKS support role. The last several years have been focused on SOLIDWORKS PDM Professional (formerly Enterprise PDM).
View all posts by Jim Ward
