Enabling the SOLIDWORKS PDM Add-in
Article by GoEngineer on Dec 30, 2024
Whether you’re using PDM Standard or PDM Professional, you can interact with SOLIDWORKS files in two ways: directly in the PDM vault or through the PDM Add-in fly-out panel in SOLIDWORKS.
This interaction includes, but is not limited to: checking a file in and out, reviewing a file’s version and associated file versions, and getting previous versions of a file*.
How to Enable the SOLIDWORKS PDM Add-in
*Note: The get version command is only available if the Enable the get version command in SOLIDWORKS Add-in is selected from the user/ group settings. Review the “Always work with Latest…” section of Controlling Access to Versions and Revisions in SOLIDWORKS PDM for more information.
Enable the Get Version Command in SOLIDWORKS Add-in Checkbox Admin-Properties
Locating the Add-in
If you haven’t installed SOLIDWORKS PDM on your machine, check out the SOLIDWORKS PDM Client Installation on an Existing SOLIDWORKS Installation article for the necessary steps.
To enable the add-in, go to Tools > Add-Ins, and select the checkbox to the left of SOLIDWORKS PDM.
You'll probably want the PDM panel to open automatically when you launch SOLIDWORKS. To do this, ensure the checkbox to the right of the “SOLIDWORKS PDM” add-in is selected.
Note: In the event the add-in is not listed in the available list, the Troubleshooting section below identifies how to install it.
SOLIDWORKS Premium SOLIDWORKS PDM Add-in
Troubleshooting
  1. CAD software functionality (CAD Add-In) is only available to users with a SOLIDWORKS PDM Editor & Web license type. Therefore, the following error is an indication that the user is either set up with a Contributor and Web or Viewer license type.
    SOLIDWORKS PDM Message The Operation is Not Supported by your SOLIDWORKS PDM License
    For instructions on modifying the client type, review the Changing SOLIDWORKS PDM License Types article.
  2. The SOLIDWORKS PDM Add-In is installed as an extension to the SOLIDWORKS PDM Client Installation. The SOLIDWORKS PDM Client Installation on an Existing SOLIDWORKS Installation guide covers where to find the checkbox to include this:
    SOLIDWORKS PDM Client Options SOLIDWORKS Add-in
I hope you found this article helpful. Check out more SOLIDWORKS PDM articles listed below.
How to Install the SOLIDWORKS PDM Server
How to Create Dynamic Lists in SOLIDWORKS PDM Standard Data Cards
SOLIDWORKS PDM - Implement Working Revisions
VIEW ALL SOLIDWORKS ARTICLES
