This article explains how to quickly switch the SOLIDWORKS PDM license types on a per-client basis. This method works for both SOLIDWORKS PDM Professional and SOLIDWORKS PDM Standard.
You pick the client license type during the SOLIDWORKS PDM installation process, so naturally, you can modify the installation (if it’s not an administrative image) and change the license type that way. If you have time, you can uninstall and reinstall with a different client license type. You can also use the SOLIDWORKS PDM Administration tool and change it on the fly. Before we get into what changes we’ll be making in the admin tool, let’s recap the different license types.
Pro Tip: To change the license type if the client was installed using an admin image, you’d have to uninstall and reinstall with a new admin image with the correct license type.
First, head over to the Administration tool found in the SOLIDWORKS PDM folder under All Programs and right-click Administration and Run as Administrator. Making this change will modify some values in the registry which is why the elevated permissions are needed.
Next, click on Help > About SOLIDWORKS PDM Administration…
Note: In newer versions of PDM, you can alternatively click on the question mark icon in the top-left to open the client dialog box.
Click on the Client type drop-down and select the new license type.
After selecting your new license type, it will prompt you to restart your computer. A restart is required for the new license type to take in.
Editor's Note: This article was originally published in March 2017 and has been updated for accuracy and comprehensiveness.
Linking Configuration-Specific Information to a SOLIDWORKS PDM Data Card
How to Set Up Dynamically-Controlled Card Lists in SOLIDWORKS PDM
How to Search for Variables That Have Been Left Blank in SOLIDWORKS PDM Data Cards
Default Expressions in SOLIDWORKS PDM Data Cards
