SOLIDWORKS PDM Standard is a great data management tool included with SOLIDWORKS Professional and SOLIDWORKS Premium. However, it is built on an SQL Express database, which unfortunately means there are no automated maintenance plans in SQL Server Management Studio. This makes automating the SQL backup procedure more difficult, but, as we will explain in this document, it is possible.
First, we need to clarify some assumptions. The information below assumes you have SQL Express, SQL Server Management Studio, and PDM Standard already installed on a server. If you need assistance installing the software, please feel free to contact our services team for information. If you recently completed a PDM Jumpstart with GoEngineer, all the necessary PDM components have been installed as a part of your services.
Even if you used GoEngineer’s Jumpstart services for PDM Standard implementation, GoEngineer is not directly responsible for your backups and is not specifically recommending any of the methods below. It is your company’s responsibility to look over the information and decide the best course of action for your team.
This document serves to explore three methods to automate the SQL backup process without installing any additional software. It is simply a method to accomplish backups without purchasing, downloading, or installing additional software on the server.
There are various utilities on the internet to accomplish backups, including a few paid and free utilities for backing up SQL Express.
Some options include:
Note: GoEngineer does not specifically recommend these products nor can guarantee effectiveness. These utilities are not GoEngineer or SOLIDWORKS products, and they are for information purposes only.
To better understand which PDM components we need to back up, we need to understand which PDM components are necessary for a restore in the event of a failure.
There are three components necessary for a full PDM restore:
Please verify the location for the Archive Server Folders before attempting to back them up. It is possible to find the location of the Archive Servers by logging into the PDM Server. Press Start and search for the SOLIDWORKS PDM Archive Server. Expand Computers, Select Archive, then right mouse click on the vault you want to backup. Select Properties > Relocate and copy the Path shown below to see where your archive folders reside.
Contact your IT department to see what imaging software you will need to image and back up the folders in the specified Archive Server folder location.
On the PDM Server, press Start and search for the SOLIDWORKS PDM Archive Server. Select Tools > Backup Settings as shown below. Set a location and set it on a routine schedule for backups. It is a good idea to backup these files in the same location as the SQL backups.
There are three ways to accomplish an SQL backup with free tools. This depends on how you like to perform your backups. A description of each method is below.
Backup Method 1: Backup with multiple unique backup files. Backup up one database. It does not back up the ConioMasterDB by default.
Backup Method 2: Backup with a single backup for each database. No history. Most simple solution.
Backup Method 3: Backup with multiple unique backup files. More options are available for full, differential backups as well as options to specify additional databases to back up.
All backup methods require the SQL command-line utility (SQLCMD) to be installed. The sqlcmd utility lets you enter Transact-SQL statements, system procedures, and script files.
For SQL Server 2014 and lower versions, the utility is shipped as part of the product. No download or separate installation is required.
For SQL Server 2016 and 2017, the sqlcmd utility is offered as a separate download. For more information, review sqlcmd Utility.
Command Line Utilities 15 download: https://go.microsoft.com/fwlink/?linkid=2142258. For SQL Server 2019, the utility is shipped as part of the product. No download or separate installation is required.
Figure 1: Installation location for SQL Server 2019
GoEngineer Article: SOLIDWORKS PDM Standard – Backup SQL
Summary:
Uses two scripts to produce a backup of a single database. One script contains SQL commands to create the database backup file. The second script is a Windows batch file that calls the SQL script and runs a command to remove older backup files. For backup history, a parameter in the Windows batch file controls the number of backups to keep. If multiple vaults are present or if the ConisioMaster and vault databases are to be backed up, another set of SQL and Windows scripts must be customized for each additional database(s).
Variables are used to set Instance\database name, backup file location\name, script location, and the number of backups to keep.
The Windows batch file can be run manually or can be automated using Windows Task Scheduler. Information on how to automate using the Windows Task Scheduler can be found in the How to set up the batch file to automate using the Windows Task Scheduler section.
Using this method, you end up with:
A folder containing multiple unique backup files. The number depends on the “backups_to_keep” variable value.
We have pre-written the batch file and SQL file. Simply download this file and change the required values to match your database(s) indicated in the original content.
GoEngineer Article: SOLIDWORKS PDM Standard Automated SQL Backup
Summary:
This method assumes you are looking to automate the SQL backup procedure for the PDM databases in SQL.
This method uses a single Windows batch file containing SQL commands to create the database backup file. Each line will back up a single database. Multiple lines can be added to back up multiple databases in a single script. No backup history is preserved as the backup files are overwritten each time the script is run. Instance\database name and backup file location\name are fixed parameters in each command line.
Summary:
Backup Method 3 uses a single Windows batch file containing SQL commands to create the database backup file. A single command line can be used to back up all databases in the instance or multiple lines can be added to back up a single selected database per command. For backup history, a parameter controls the number of backups to keep.
Variables are used to set Instance\database name, backup file location\name, script location, and the number of backups to keep. Additional parameters can be set on the command line to pass to the stored procedure.
Prerequisites:
A folder containing multiple unique backup files. The number depends on the “backups_to_keep” variable value. There are two options for executing method 3, simply comment out the option you do not plan on using.
A prewritten download for both Method 3 Options 1 and 2 can be found here. You can edit either of these documents with your backup location and SQL instance. If you would like to set this up yourself, follow the below steps. Only one batch file is necessary to run this backup.
Step A: Create a stored procedure to back up your databases
Connect to your SQL express instance and create sp_BackupDatabases stored procedure in your master database using the script at the following location: SQL_Express_Backups
Step C: Create batch file using text editor
In a text editor, create a batch file that is named PDM_Std_backup.bat, and then copy the text from either of these files for option one and two in method 3 and save as a batch file (.bat).
This backup script is set up to use Windows authentication to connect to SQL. If you are using SQL authentication, ensure that access to the folder is restricted to authorized users as the passwords are stored in clear text.
All the batch files created in the document can be automated using Windows Task Scheduler. Follow these step-by-step instructions:
References:
https://docs.microsoft.com/en-us/troubleshoot/sql/admin/schedule-automate-backup-database
Copy and pasted stored procedure from Microsoft here.
Collaborating Author: Brian Patterson
Brian is an Application Engineer at GoEngineer specializing in SOLIDWORKS PDM and PDM implementation. He has over 20 years of CAD experience and has been with GoEngineer since 2014. Brian is based out of our office in Santa Ana, California.
About Jacob Bakovsky
Jacob is a Senior Elite Application Engineer at GoEngineer. His expertise is in SOLIDWORKS but he also has knowledge with PDM, Composer, Inspection, Visualize, Simulation, and the 3DEXPERIENCE platform. In addition, he also helps run the 3D printing service bureau at our Santa Ana, California branch.
