SOLIDWORKS offers a versatile set of options under Model Display, allowing users to personalize model visuals for parts and assemblies. Key features include setting custom colors, adjusting edge styles, and applying advanced surface attributes like transparency and texture scaling. This ensures accurate visual representation and smoother design reviews. You can also store custom appearances and optimize model sharing with integrated textures, decals, and lighting effects.
Where are Model Display Properties Located?
With an assembly or part document opened, model display properties can be accessed underTools>Options>Document Properties>Model Display.
Explanation of Settings
These settings allow you to control and enhance model presentation for better design communication and customization in SOLIDWORKS. Below is an explanation of each setting.
Model/Feature Colors:Allows the use of specific colors for specific features. For assemblies, options includeShading(for shaded mode) andHidden(for hidden lines visible mode). IfUse component color in HLR/HLVis off, wireframe view is also available.
Edit:Opens the color selection box, letting you specify the exact color for model elements. In the image below, fillets were changed to red. This updates the model to change all fillets to the applied color.
Advanced:Adjusts advanced visual properties such as ambient lighting, reflectivity, shininess, and transparency, giving you fine control over the appearance. TheAdvancedoption is only available when selectingShadingunderModel/Feature Colors.
Curvature:Sets curvature display options, useful for visualizing complex curves and surfaces within the model. Values can be modified on the color scale. The colors will be shown when using theCurvaturecommand located on theEvaluatetoolbar.
Reset Colors to Defaults:Restores all custom color settings to the SOLIDWORKS default colors.
Apply Same Color to Wireframe, HLR, and Shaded:Ensures consistency by applying the same color to wireframe, hidden lines removed (HLR), and shaded views. Applicable for assemblies whenUse component color in HLR/HLVis off underView>Display. WhenUse component color in HLR/HLVis on, it will show the component color.
Reset To Default Name:Resets any renamed comment back to SOLIDWORKS default comment names.
Ignore Feature Colors:Used in part models only, this setting lets part colors override individual feature colors. Essentially, this will ignore the colors that have been set underModel/Feature Colors.
Go to System Colors: Opens the System Colors settings, where you can adjust colors used across the SOLIDWORKS interface. These can also be found underTools>Options>System Options>Colors.
Store Appearance, Decal, and Scene Data in Model File: Saves customized appearances, decals, and scene settings within the model file for easier sharing, increasing file size.
Store Images for OLE Object Data in Model File: Saves embedded OLE objects like Microsoft Word and Excel documents within the model file for easier sharing, increasing file size.
Automatically Scale Appearance Textures, Surface Finishes, and Decals to Model Size: Scales textures and finishes to fit the model’s dimensions. When off, it uses a default scale to approximate real-world appearances.
Cartoon Edge Thickness: Adjusts the width of cartoon-style edges; useful for achieving a stylized visual effect. To turn on cartoon edges, go toView>Display>Cartoon.
Model Display Properties is a powerful set of tools to enhance the display of your models or even highlight specific parts of the geometry.
I hope you found this article for mastering SOLIDWORKS Model Display Properties helpful. Check out more tips and tricks below. Additionally, join the GoEngineer Community to participate in the conversation, create forum posts, and answer questions from other SOLIDWORKS users.
SOLIDWORKS CAD Cheat Sheet
Alert
