SOLIDWORKS has powerful solid modeling tools that can help create virtually any shape or design imaginable. However, you may get stuck trying to accomplish something, and all the solid modeling tools you've tried, won’t do the trick. In times like these, use SOLIDWORKS Surfacing tools!
SOLIDWORKS Surfacing tools are incredibly useful when solid modeling just isn’t enough. However, it can get very messy very fast. SOLIDWORKS Surfacing tools should be used sparingly and only when necessary. However, they can be a niche solution in a tight spot.
In this article, you'll learn about three useful SOLIDWORKS Surfacing tools and techniques to start incorporating into your modeling:
Hopefully, they will spark your interest in further exploring the SOLIDWORKS Surfacing features.
Rather than go through a menu for every feature, enable the surface features tab in your SOLIDWORKS CommandManager by right-clicking any of the tabs and checking Surfaces.
Figure 1: Enabling the Surfaces features tab in the CommandManager
It is also useful to set your Surface and Solid Bodies folders to always show in the FeatureManager. Go to Tools > Options > FeatureManager and set the Solid Bodies and Surface Bodies folders to Show.
Figure 2: SOLIDWORKS System Options window
In your FeatureManager, you will now see this:
Figure 3: FeatureManager now showing Solid Bodies and Surface Bodies
When you begin to incorporate hybrid modeling, your end result should always be a solid body. Ensuring that the Surface Bodies folder always shows will be an easy check to know that you have successfully transitioned back to a solid body.
There are many ways to create features of internal geometry. One useful surfacing tool is the Copy Surface feature. For example, I have this part:
Figure 4: Example part
I want to create a male part and calculate the internal volume.
In some cases, the desired result is to remove geometry from a part and leave no trace of its existence. This can be done by rolling back and deleting the original features, but this may cause trickle-down problems with subsequent features. In this instance, the Delete Face feature is a niche tool. In this example, I will use this part:
Figure 9: Example part: snowmobile hood
Although the Move Face feature is not on the Surfaces tab by default, it is still a surfacing tool. This tool comes in handy when you need to modify imported geometry with no feature history.
For this example, I will use this baffle:
Figure 12: Example part: baffle
The only feature I have is the Imported1.
Hybrid modeling can be a very niche tool when you get stuck with solid modeling. As I mentioned before, surface modeling should be used sparingly and only when necessary, but when used appropriately, it can help solve seemingly impossible modeling tasks.
To learn more about surfacing, check out our YouTube channel and the articles listed below.
How to Use the Import Diagnostics Tool in SOLIDWORKS
How to Create an Offset Surface without Failed Faces in SOLIDWORKS
Creating a Non-circular Helix in SOLIDWORKS with Surfacing Commands
Removing External References in SOLIDWORKS Files
About Preston Ruff
Preston Ruff is a Technical Support Engineer and Certified SOLIDWORKS Instructor based out of our Headquarters in Salt Lake City, Utah. He earned a Bachelor’s degree in Manufacturing Engineering Technology from Brigham Young University and is a Certified SOLIDWORKS Expert. For many years, Preston has been passionate about CAD design, 3D printing, additive manufacturing, and being involved with STEM education. He joined the GoEngineer family in 2017.
