We all know how to make a helix in SOLIDWORKS, right?
Well what if you needed to create a non-circular helix? Think squares, rectangles, slots, etc. How would you create that? The Helix command and Spiral command in SOLIDWORKS can only be created from a sketch circle. So, what are your other options?
Recommended Video: Helix Along Path
"I’ll just sketch it myself, pattern a repeating group, and finish with a Sweep feature!”
Unless you want to spend your entire workday 3D sketching to extreme exactness this is not the best option.
To solve this conundrum, we’ll do what all good solid modelers do in a pinch: try surfacing commands!
In this post, I will illustrate an example of creating a rectangular spring in SOLIDWORKS using clever surfacing and curve commands.
I hope you found this tutorial for creating a non-circular helix helpful! Check out more SOLIDWORKS tips and tricks below.
Removing External References in SOLIDWORKS Files
How to Color Sketches in SOLIDWORKS
SOLIDWORKS Cosmetic Thread Upgrades
