In SOLIDWORKS, solar access studies are a kind of motion study used to simulate the motion of the sun as it passes over a model. This type of study is useful for applications like deciding where to place solar panels on a roof.
The first step in setting up a solar access study is to add sunlight to your model. Sunlight is a kind of light available in SOLIDWORKS Professional and SOLIDWORKS Premium. The properties of this light are determined by the location, date, and time specified in the Sunlight PropertyManager. Unlike other kinds of lights, only one sunlight can be added to any part or assembly.
To add sunlight to a model, go to View > Lights and Cameras > Add Sunlight.
Figure 1: Add Sunlight Feature Location
Doing so will open the Sunlight PropertyManager.
Figure 2: Sunlight PropertyManager
A compass will appear in the graphics area indicating which direction is North. To change this, pick a planar face or an edge to populate the North direction selection box.
You can then set the location, time zone, date, and time. The Advanced tab includes additional options for haze, sun diameter, ground albedo, and sky gamma. There are several default locations from which you can choose or enter custom coordinates. To set the date to an equinox or solstice, click the down arrow button next to the Date text box.
Once sunlight has been added to the model, the next step is to create a Motion Study. In the MotionManager, click the Animation Wizard button.
Figure 3: Animation Wizard Button
In the dialog that appears, the Solar Access Study option is now available.
Figure 4: Animation Wizard Dialog
There are two kinds of Solar Access Studies:
Once you have gone through the Animation Wizard, click the Play from Start button to run the study. The background of the graphics area will change and shadows will move over the model.
Figure 5: Play from Start Button
And that's how to set up a solar access study in SOLIDWORKS.
Check out this YouTube video for a demonstration of the tools and methods discussed in this article.
Want to become an expert? Learn to study kinematics and dynamic behavior of your SOLIDWORKS assembly models in the official SOLIDWORKS Motion training course offered by GoEngineer.
Save SOLIDWORKS Motion Study Positions
SOLIDWORKS Motion: A Tip for Handling Performance "Hogs"
How to Set Up a Thermal Study in SOLIDWORKS Simulation Professional
SOLIDWORKS Motion Utilizing Design Studies to Evaluate What-If Scenarios
About Lauren McGarry
