SOLIDWORKS PDM SQL Tables Commonly Used in Queries
Article by Brandon Harris on Dec 08, 2020
This article is an introduction to some of the SQL tables more commonly used in queries. Many of these tables fall into two categories. The first identifies a list and gives them ID’s. The second lists the use of those attributes by file. A good example of this is the Transitions table identifies each of the transitions in the workflows, and the TransitionHistory Table lists all the transitions that any file has gone through. In this case, the Transitions table is used to give meaning to the TransitionNr listed in the Transitionhistory table.
For more information on the use of these tables see:
Attribute
This table lists the Block name, and attribute for all the SOLIDWORKS PDM Variables.
Documents
This table is the main table used to identify each file using the Document ID, and File name.
DocumentsInProjects
This table links the Documents and the Projects tables. Allowing you to link the file name to the file location.
Groups
This table Identifies the user groups by ID
GroupMembers
This table links the Groups table and the Users tables.
Projects
This table Lists the folder and the file location for each file.
Revisions
This table lists the revisions for each file.
Status
This table identifies the Workflow States by ID.
Transitions
This table identifies the Workflow Transitions by ID.
TransitionHistory
This table lists each State transition any file has gone through. Other useful information here could be the user who initiated the state and the revision.
Users
This table Is used to link the UserID to the Username. Also, you can use this table to correct misspelled usernames not governed by the active directory.
Variable
This table identifies the Variables by ID.
VariableValue
This table lists the values for Each variable for each file, revision, and configuration
Workflows
This table identifies the Workflows by ID.
Xrefs
This table lists files that are referenced by a file.
Tables
Attribute
AttributeID
VariableID Links with variables table
AttributeName
BlockName
AttributeType
Documents
DocumentID This id is used to identify each document
Filename Name of file
LockProject
UserID Links with Users Table
LockDomain
LockPath
Busy
Flushed
DefValStored
RevGenCounter
LatestRevisionNo
CurrentStatusID Links with Status table
WorkingVersionModified
ExtensionID
LockDate
UserDocRefsModified
Deleted Boolean value 1= has been deleted
Shared
LockViewID
Link
DocTypeID
ObjectTypeID
Flags
DocumentsInProjects
ProjectID Links with Projects table
DocumentID Links with Documents table
Deleted
Groups
GroupID
Groupname
Description
AutoAdd
GroupMembers
GroupID Links with groups table
UserID Links with users table
ProjectID
IsMember
Projects
ProjectID ID used to identify the folder
Name Name of folder file is located in
StatusID Links with Status Table
StartTime
Deadline
TimeEstimate
Busy
MoveCount
Path Path to file
Deleted
FolderType
Revisions
DocumentID Links with Documents Table
RevNr
Date
Comment
FileSize
FileDate
Root
WebRoot
ProjectName
FlushedDate
LockDate
ActiveConfigurationID
VersionUID
FileTimeStamp
IsOverwritten
Status
StatusID
IconName
Name State name
BoxXPos
BoxYPos
BoxWidth
BoxHeight
Enabled
Description
RevNumID
BlockRights
WorkFlowID Links with Workflows Table
StatusType
RevisionVarID
Transitions
TransitionID
Name
Source Links with StatusID
Destination Links with StatusID
BoxXPos
BoxYPos
BoxWidth
BoxHeight
Enabled
Description
ConditionSQL
ArrowNodeIndex
WorkflowID Links with Workflows table
Authentication
SrcStatusName
DestStatusName
ExtWorkflowLinkGUID
Type
HideWhenParSiblingUsed
LatestVersionOverwrite
TransitionHistory
TransitionNr
RevNr
Date
Comment
TransitionID Links with Transitions Table
PostActionVerNo
Users
UserID
Username
Enabled
LoggedIn
SessionID
Email
SettingsTableVersion
FullName
Initials
UserData
InitialStatusID
Variable
VariableID
VariableName
VariableType
IsDeleted
FlagUnique
FlagMandatory
FlagFreeUpdateAllVersion
FlagFreeUpdateLatestVersion
Variable value
VariableID Links with Variable Table
ProjectID Links with Projects Table
RevisionNo Links with Revisions Table
ConfigurationID
ValueText
ValueInt
ValueFloat
ValueDate
ValueCache
IsLongText
Workflows
WorkflowID
Name
Description
InitialTransitionID
WorkflowGUID
ExtWorkflowGUID
Xrefs
RevNr Links with Revisions table
XRefDocument Links with Documents table
XRefProjectID Links with Projects table
XRefRevNr
HasFullPath
RelativePath
RefCount
XRefID
RefCountEdit
RefTimeStamp
XrType
SOLIDWORKS PDM Web2 Guide: Server Setup, Accounts, Application Pool, & Testing
Option File - A Great Solution for Managing Your SNL(s)
Fixing SOLIDWORKS PDM Error Message: The Program and the File Vault Are Of Incompatible Versions
SOLIDWORKS PDM - Complete Guide to Client Installation
SOLIDWORKS PDM - Guide to PDM Standard Backups
About Brandon Harris
Brandon is a BYU-Idaho graduate with a Bachelor’s Degree in Mechanical Engineering. He is an avid tinkerer, and consummate rapid prototype hobbyist with prior experience designing for the Architectural/Construction industry. Brandon is part of the technical support team for GoEngineer serving as a PDM specialist since August 2018.
View all posts by Brandon Harris
