Adding numbers to a SOLIDWORKS model can be a repetitive and time-consuming process. In some cases, this process can be made easier using SOLIDWORKS pattern tools and their Instances to Vary function. Let’s look at the setup and applications of this feature.
In this example, I have a 6” ruler that needs numbers to designate the appropriate length markings.
I need to establish, numerically and spatially, where the number series should start. In this case, I will begin incrementing from the 0.5” mark and continue in half-inch increments through 5.5”.
To accomplish this, I need to link a starting dimension value that will be incremented, to a custom property (in this case called “Start”). I will then need to link that custom property to sketch text used to emboss or etch the resulting value on the part.
The resulting pattern will automatically increase by 0.5” units per instance generating the measurement marks.
The instancing can vary in multiple directions and at different increment values. Here the x-axis is incremented by 1, while the y-axis is incremented by 10.
Change the starting value and increment to “2” for even numbers.
Utilize a circular pattern to generate the hours on a clock.
You can also pattern across multi-body parts for part numberings.
There are several ways to use pattern tools to increase productivity and reduce repetitive tasks. I hope this article gives you insight on how to better leverage the power of SOLIDWORKS pattern features and their Instances to Vary function.
Want to learn more? Check out more tips and tricks below. Check out more tips and tricks below. Additionally, join the GoEngineer Community to participate in discussions, create forum posts, and answer questions from other SOLIDWORKS users.
SOLIDWORKS Sketch Relations Guide
SOLIDWORKS Fill Pattern Tool Explained
SOLIDWORKS Variable Pattern Tool Explained
Importing a Vector Logo into SOLIDWORKS
About Chris Villeneuve
Chris Villeneuve is a SOLIDWORKS Technical Support Engineer at GoEngineer.
