If you have ever wanted to pattern a feature and have the patterned instances vary in size/shape/location, the SOLIDWORKS Variable Pattern tool can help. SOLIDWORKS understands how the original geometry was created and uses that design intent to create each instance in the pattern. In this tutorial, we'll use a few different examples to explain how the tool works.
Variable Pattern can be accessed by going to:
or
For this example, we have a model of a colander with a slot on the bottom surface. We will create a Variable Pattern of this slot and specify some dimension parameters to get variation in the patterned instances.
For the remainder of this example, we will look at a few ways we can edit/modify a Variable Pattern.
Let’s modify one of the instances manually using Instant3D. On the Feature Toolbar make sure Instant3D is enabled.
Select a face on one of the instances to pull up the dimensions. We can drag the grip on the dimension to enable the ruler, then drag the dimension to the desired value.
The geometry is updated, and the dimension value changed for that individual instance. If the table were edited, it would show the updated value for the Slot length as well.
Next, expand the Variable Pattern Feature in the Feature Manager Design Tree. Notice that all instances are listed below the feature. Right-click on one of the instances. We can delete an instance, which will remove it from the table, or suppress an instance, which leaves table information intact but removes the geometry.
To edit the table, right-click on the Variable Pattern feature and choose Edit Feature. Click Edit Table Pattern in the Variable Pattern PropertyManager as previously mentioned.
In this example, we have the sole of a soccer shoe with cleats varying in size, position, and rotation angle.
Editing the Variable Pattern feature reveals the use of a Position 3DSketch and a plane normal to the sole’s surface at the sketch point. This is to drive the position of the instances.
Editing the Pattern Table reveals the dimensions for the Position-3DSketch, plus the Angle and Length of the Spike Sketch.
Click on the Variable Pattern to see the dimensions for each instance. Any dimension can be edited on the fly to update the pattern.
In this example, we have tread on the sole of a shoe made with two Variable Patterns. Extra cuts were placed into the soles after the Variable Pattern.
The Seed Features were made with a Thin-feature Cut Extrude using a Spline sketch.
Editing the Pattern Table reveals the dimensions to make the Spline sketch and the depth of the Cut Extrude for each instance. This changes the size, shape, location, and depth of each instance.
The SOLIDWORKS Variable Pattern tool is powerful allowing extreme flexibility in your patterns and design intent, without having to recreate similar geometry. I hope this was informative to you and thank you for choosing GoEngineer.
Favorite SOLIDWORKS Capabilities: Component Patterns
How to Create a Varied Sketch Pattern in SOLIDWORKS
Create J-Slots in SOLIDWORKS on Cylindrical Parts
Display SOLIDWORKS Sheet Metal Surface Area in Your Bill of Materials
About Zach Brown
