Using the SOLIDWORKS Temporary Fix/Group Command
Article by Matthew Kusz on Apr 19, 2022
Mates are used in SOLIDWORKS Assemblies to constrain the location and interaction of components. (New to using Mates? Check out this Introduction to SOLIDWORKS Mates) It is sometimes useful to temporarily lock certain components in place. Rather than add new Mates (only to remove them moments later), SOLIDWORKS has the ability to fix components temporarily and define groups to quickly lock things down or move many components at once.
First, let's define what fixed and floating components are and how to identify them inside your Assembly.
By default, when creating a new Assembly in SOLIDWORKS, the first component you insert is "fixed" in place, while later components are allowed to "float".
SOLIDWORKS Make Assembly from Part Option
SOLIDWORKS Begin Assembly Accept Default Location
Fixed Components in SOLIDWORKS Assembly
The fixed/float status of a component can be easily toggled by right-clicking it. If the component is already fixed, the menu will show the Float option. Likewise, if the component is floating, the Fix option will be available.
Fix and Float Option in SOLIDWORKS
In the Assembly FeatureManager Design Tree, a fixed component is represented with the letter (f) in front of the part or subassembly name. A (-) prefix means that it is floating (not fixed), and under-defined. A fully-defined component has no prefix.
Floating Components (f) SOLIDWORKS Assembly
Temporary Fix/Group
Now let's take a look at the Temporary Fix/Group command inside SOLIDWORKS.
In the Assembly below, I want to move the robot arm, but when I click and drag the gripper, the gripper subassembly turns instead. I can remedy this by temporarily grouping the subassembly to its mount using the Temporary Fix/Group command.
SOLIDWORKS Temporary Fix Group Command
In SOLIDWORKS 2021 and newer, Temporary Fix/Group is located in the Tools menu, under Evaluate.
Access Temporary Fix/Group from SOLIDWORKS Tools Menu
The Search command, ('s' on the keyboard) is also an easy way to locate it.
Search for SOLIDWORKS Temporary Fix/Group Command
Opening the command will display two selections Components to fix and Components to group. I have chosen the two components to group and can select Fix/Group in the lower left-hand corner of the window.
SOLIDWORKS Components to Group
Using the Temporary Fix/Group Command in SOLIDWORKS
Now when I select to drag this assembly, it will allow me to pivot up without rotating my subassembly.
Tutorial Using the SOLIDWORKS Temporary Fix/Group Option
If I click to exit, my assembly returns to the constraints I had prior to this temporary fix command.
To learn more about Temporary Fix/Group, check out the resources below.
More SOLIDWORKS Tutorials
Easy Ways to Model a Wye Pipe in SOLIDWORKS
SOLIDWORKS Variable Pattern Tool Explained
Create J-Slots in SOLIDWORKS on Cylindrical Parts
SOLIDWORKS Sketch Text Tool Overview
How to Repair Broken References in SOLIDWORKS
VIEW ALL SOLIDWORKS TUTORIALS
About Matthew Kusz
View all posts by Matthew Kusz
