Given that SOLIDWORKS Simulation is capable of running a transient thermal analysis on models it leads to the question of whether the transient temperatures of a model induce catastrophic stresses. Through the application of a Design Study, SOLIDWORKS is capable of calculating thermal stress values for each time step of a transient thermal analysis.
In this example setup, the filament of a light bulb is being heated with a 0.1 Watt source. All heat is being lost to radiation so the glass bulb and plug assembly can be removed to simplify the study and speed up the analysis. Further, thermal resistance is used between the wires and the filament to approximate a complex connection that might inhibit heat transfer and in this instance.
Figure 1: The original bulb model is shown on the left with the simplified analysis model of only the filament wire shown to the right
This transient thermal study contains 3 bodies (2 wires and 1 filament) adjoined with “Thermal Resistance” contact sets. The thermal loads applied to the model are an initial temperature of room temperature, a heat power, and a radiation definition with an ambient temperature set to room temperature. The thermal study boundary tree will look similar to Figure 2.
Figure 2: Thermal study boundary tree showing radiation cooled setup for the filament
Running this study should give temperature results for all time increments that will then feed into a static study.
The static study still contains all three previous bodies adjoined with “Bonded” contact sets. The free ends of the wires, where they connect to the plug contacts are fixed and the only load applied is a “Thermal Effects” load that transfers the temperature results from the thermal study to run a thermal stress analysis. The static study boundary tree will look similar to Figure 3.
It is not important to run the static analysis but you will return to this static study to link a parameter from the Design Study.
Having a transient thermal and static study set up the operation to use them in conjunction with each other to obtain stress results at each time step will be to use a Design Study. The exact process will go as follows:
The final result is a Design Study which reports the maximum stress value due to each time step of the transient thermal analysis as illustrated in Figures 3 and 4.
Figure 3: Design Study results showing values of stress for each thermal time step
Figure 4: A graphed representation of Stress vs. Time from the Design Study results
Backspin is Important to your Basketball Free throw! A SOLIDWORKS Simulation Study
SOLIDWORKS Simulation Tips: No Penetration Contact Set Setup
A Guide for Bearing Connectors in SOLIDWORKS Simulation
About Ryan Dark
