When attempting to access one of the SOLIDWORKS ‘Xpress’ products (e.g., SimulationXpress, FloXpress, DriveWorksXpress, or DFMXpress), you might encounter the message "The code you have entered is not valid for your serial number, SOLIDWORKS version, or the selected Xpress product."
If this message appears, the first suggestion is as follows:
If the issue is still present, perform the next set of steps as follows:
If the issue is still present, contact your IT department and have them log in using a different Windows user account with full Administrator permissions, and then repeat the procedure listed above.
Thereafter, if the issue is still present while using an administrator user account, the next step entails generating an Rx Problem Capture zip file that captures steps taken in the registry editor and the subsequent behavior when attempting to enter the code for the Xpress product.
If GoEngineer is your reseller and you would like us to help you with this process, then please feel free to reach out to Technical Support.
I hope you found this helpful. Check out more SOLIDWORKS articles below. Additionally, join the GoEngineer Community to participate in the conversation, create forum posts, and answer questions from other SOLIDWORKS users.
Obtaining and Using SOLIDWORKS Certification Exam Vouchers
McMaster-Carr SOLIDWORKS Add-In: Installation & Use
What is Make Independent in SOLIDWORKS?
Getting Started with the SOLIDWORKS Design Library
About Jonathan Sauerbrey
Jonathan is a Sr. SOLIDWORKS Support Engineer at GoEngineer
