SOLIDWORKS Sheet Metal: Export Flat Pattern to DXF File
Article by Greg Buter on Jul 26, 2024
Did you know that generating a DXF file from the flat pattern of your SOLIDWORKS Sheet Metal part can be achieved in just a few seconds? Let’s walk through it using an example of a battery tray designed for a radio-controlled car.
First, right-click on the main face of your SOLIDWORKS Sheet Metal part and select Export to DXF / DWG.
SOLIDWORKS Sheet Metal Part Export to DXF / DWG
Next, save the DXF file with your desired file name and location.
Save a DXF File with Desired File Name and Location in SOLIDWORKS
In the options, select Sheet Metal.
Sheet Metal Options in SOLIDWORKS
Finally, a cleanup tool will pop up. This shows a preview and gives you a chance to remove any entities before the DXF is generated. If your model had countersink geometry or engravings, you might decide to remove them from the DXF file before it goes to laser cutting. Clicking on Save will complete the process.
Remove Entities Before DXF is Generated in SOLIDWORKS Sheet Metal
The newly created DXF file is easily imported into CNC software to cut out the flat pattern.
DXF File Imported into CNC Software to Create Flat Pattern Sheet Metal Part
Using the SOLIDWORKS bend lines, adding the bends to the sheet metal blank is easy.
Using SOLIDWORKS Bend Lines to Create a Sheet Metal Blank
Now, we have our completed battery tray installed on our toy car.
SOLIDWORKS Sheet Metal Tutorial Export Flat Pattern to DXF File for Toy Car Design
Exporting our flat pattern to a DXF file directly from the SOLIDWORKS part file is incredibly simple. This process makes quick work of getting our SOLIDWORKS Sheet Metal parts to production.
I hope you found this SOLIDWORKS Sheet Metal quick tip helpful. Check out more tips and tricks listed below. Additionally, join the GoEngineer Community to participate in the conversation, create forum posts, and answer questions from other SOLIDWORKS users.
Want to take your SOLIDWORKS skills to the next level? Enroll in the official SOLIDWORKS Sheet Metal training course. Both online and in-person classes are available.
More SOLIDWORKS Sheet Metal Tutorials
SOLIDWORKS Sheet Metal Sketched Bend Tutorial
Show Sheet Metal Bend Lines in a SOLIDWORKS Drawing
[VIDEO] Creating a Round-to-Square Sheet Metal Transition in SOLIDWORKS
SOLIDWORKS 2024 Sheet Metal Updates – See What’s New
About Greg Buter
Greg Buter is a SOLIDWORKS Engineering Manager at GoEngineer.
View all posts by Greg Buter
