Show Sheet Metal Bend Lines in a SOLIDWORKS Drawing
Article by Ryan Field on Jun 26, 2023
We often hear from customers looking for ways to show Bend Lines on the drawing of sheet metal parts. There are several ways to get Sheet Metal Bend Lines to show (or not show) in a SOLIDWORKS drawing. This quick tutorial explains how.
Where to Find Bend Lines
First, we need to know where the Bend Lines are stored/created/saved. In a part generated with the Sheet Metal tools, Bend Lines are stored in the Flat Pattern feature. Show/hide and suppress/unsuppress to control how and when these sketches are displayed. By default, they are always in the Folded configuration, unsuppressed and hidden, and in the Flat configuration, unsuppressed and set to shown.
Where to Find Bend Lines in SOLIDWORKS
On the drawing side of things, by default, when inserting a Flat Pattern View from the View Palette or the Model View command, it will auto-generate a derived configuration in the part file and drop in the Flattened view with Bend Notes.
Show Sheet Meal Bend Lines in SOLIDWORKS Drawings
If your view does not display properly, here is what you want to look at:
No Bend Lines, but Bend Notes are Shown
SOLIDWORKS No Bend Lines But Bend Notes
First, in the Heads-up View toolbar, ensure the Hide/Show Items tool (eyeball) is not enabled. Enabled, this will hide all items.
Hide All Types SOLIDWORKS Heads-up Toolbar
If you still do not see them, prior to SOLIDWORKS 2022, your sketches are more than likely not set to View. Go to the View dropdown menu or the View Heads-up menu and select Sketches.
Control Visibility in SOLIDWORKS Sketches
In SOLIDWORKS 2022, Bend Lines were separated out from sketches, so you can hide sketches, but still keep bend lines visible. Go to the View dropdown Menu or the View Heads-up menu and select Bend Lines.
View Bend Lines SOLIDWORKS
No Bend Lines or Bend Notes are Shown
The Bend Line Sketch for that view is more than likely not set to Show. Go to the FeatureManager Design Tree, expand the View, and drill down to the Bend Line Sketch. Right-click on it and set it to Show.
SOLIDWORKS Show Bend Lines
If the bend lines were hidden in a flat pattern drawing view and the bend notes were present, the bend notes were also removed.
Hiding Bend Lines SOLIDWORKS Warning
To display missing bend notes, right-click on/in the View, select Properties, and set the bend notes checkbox to show.
Display Sheet Metal Bend Nots SOLIDWORKS Option
Note: If the bend notes were not there upon creation of the Flat Pattern view, but the bend lines were, the document property in the drawing was most likely unchecked.
Display Sheet Metal Bend Notes SOLIDWORKS Document Properties
The final issue is too many lines shown in the flat pattern. This could be a result of editing the Flat Pattern feature in the part file and unchecking the Merge faces check box. By un-checking this, you will now see the start/stop of each face. Checking this back on will remove those lines.
How to Show Sheet Metal Bend Lines in a SOLIDWORKS Drawing
More SOLIDWORKS Tutorials
Easy Way to Hide/Show SOLIDWORKS Dimensions at Part Level
SOLIDWORKS Multibody Sheet Metal Flat Pattern Drawing
Display SOLIDWORKS Sheet Metal Surface Area in Your Bill of Materials
VIEW ALL SOLIDWORKS TUTORIALS
About Ryan Field
Ryan Field is a Sr. Application Engineer at GoEngineer
View all posts by Ryan Field
