In this article, we'll discuss the functions and uses of the SOLIDWORKS Hatch tool as well as how to use it.
The SOLIDWORKS Hatch tool can be used in sketches and drawing views.
It can sometimes be useful, depending on your design intent, to have a sketch show a hatch. To do this, follow these steps:
The images below show hatching with a sketch.
Hatch within the sketch
Hatch after exiting the sketch before extruding
Extrude completed but sketch not shown
Showing the sketch with the hatch in the model view
Showing the hatch that was created in the sketch in a drawing view
Hatching can be applied using the Standard 3 Views (Top, Front, and Right) or to any view.
If you do not want to use the default hatch pattern, you can modify the hatch within the section view. (This is discussed in the next section.)
Below are some examples of hatches in a drawing.
Different types of hatches
This is a section view hatch that is placed automatically. (This can be adjusted and will be shown in the next section.)
The Hatch dialog box with the options available
Creating a solid hatch
The Hatch tool is modified by clicking on the hatch itself, or by going to Options > System Options > Area Hatch/Fill.
If you need to create a hatch for a view, do the following:
If you have an existing hatch that you want to modify, click on the hatch in the drawing and the dialog box will open. You can now make the necessary changes as shown below.
What's New SOLIDWORKS 2022: Assemblies & Drawings
Why and How to Use Display States in Drawings: SOLIDWORKS Tutorials
Displaying Expanded Metal in SOLIDWORKS Without Designing It
