How to Use SOLIDWORKS Envelope Mode
Article by Randle Wood on Oct 04, 2022
SOLIDWORKS Envelope Mode dramatically improves Top Down design performance. Envelopes are used in SOLIDWORKS assemblies as reference components and selection tools. Envelopes (part or assembly) are ignored in the bill of materials and mass properties.
The FeatureManager Design Tree icons look like this:
SOLIDWORKS Envelope Mode Icons
Note: Separate Envelope parts are a solid volume, not shelled.
Uses
  • Keep-out areas or volumes
  • Design to
    • Size, position, and mates
  • Selection sets for configurations from different sub-assemblies
  • Visibility
Getting Started with SOLIDWORKS Envelope Mode
  1. Open up an assembly in SOLIDWORKS.
  2. Right-click on a part or sub-assembly in the FeatureManager Design Tree and select Component Properties...
    SOLIDWORKS Component Properties Option
  3. Set it as an Envelope at the bottom right corner.
    SOLIDWORKS Envelope Option and Exclude from Bill of Materials Options
    Notice that when you set it to Envelope, that Exclude from bill of materials is set by default, and the icon in the FeatureManager Design Tree has changed.
    Can I Select All Components Within An Envelope?
    Yes. Right-click the envelope part and choose Envelope. There are two options:
    Select Using Envelope and Show/Hide Using Envelope Options in SOLIDWORKS
    Apply Envelope Options in SOLIDWORKS
    These options allow you to choose to Show/Hide the models that fall in or outside the envelope or a combination of selections.
    What about my drawings?
    By default, the Envelope feature(s) will be hidden. They can be shown by right-clicking View Properties > Show Envelope.
    SOLIDWORKS Envelop Drawing View Properties
    Are there any Options Settings for Envelopes?
    Yes. There are four under Colors, Assemblies, External References, Export Options…
    Component Settings for SOLIDWORKS Envelope Mode
    Export SOLIDWORKS Assembly Envelope Option
    Use case; Assembly Performance with configurations.
    I have an assembly with a bunch of small, detailed parts scattered through the tree that aren’t part of a subassembly, but I still need to design around them.
    I created a new solid Envelope part and added it to my assembly in a position that envelops all those parts. I used the process above to change that part to an Envelope.
    I right-clicked on the envelope part, selected Envelope, chose Select Using Envelope, chose Inside envelope for everything, and hit OK.
    SOLIDWORKS then reads through the tree selecting everything inside the envelope part and adding them to a selection. This makes it easy to select all those scattered parts and suppress them in short order. Now I can make a configuration of suppressed parts to speed up the performance of the top-level assembly.
    I hope you found this quick tutorial for using Envelope Mode in SOLIDWORKS helpful. Check out more tips and tricks below.
    More SOLIDWORKS Tutorials
    2 Ways to Reference a Cross-Section in SOLIDWORKS
    Improve SOLIDWORKS Decal Image with Mask
    Optimizing SOLIDWORKS for Faster Performance
    Finding and Fixing SOLIDWORKS Circular References
    7 Ways to Improve SOLIDWORKS Large Assembly & Drawing Performance
    VIEW ALL SOLIDWORKS TUTORIALS
    About Randle Wood
    View all posts by Randle Wood
