The best way for optimizing SOLIDWORKS performance is to upgrade your computer to the latest and greatest supported hardware. You should also check to make sure your graphics card and driver are supported. You can find machine recommendations here, and you can even build your own super CAD computer with the best NVIDIA Quadro graphics card, fastest Intel chip, and as much ram as your motherboard can handle.
Not everyone wants to drop another 10k on a computer though, so here are some SOLIDWORKS settings you can cahnge to speed things up until you have the cash to upgrade. Keep in mind, changing these settings for faster performance does not mean it will improve modeling performance. In fact, some of these changes will actually compromise a degree of functionality (more on this later), so before we get started you should back up your current settings so you can reverse any changes you made that end up not working out.
Slow start time? Check what add-ins are loading at start up. You can do this by selecting the drop-down menu next to Tools/Options and then add-ins. The window that pops up will show you the approximated load time for each, and allow you to choose which add-ins load automatically at start up. If you don’t use an add-in every time you launch SOLIDWORKS, then deselect it from this menu. Some add-ins, such as CAM, can cause longer launch times than others.
One way to increase speed is to decrease image quality under Tools → Options → Document Properties. This is done by moving both slider bars to low (faster) and deselecting the boxes for Optimize edge length and Improve curve quality at higher settings.
Under Tools → Options → System Options, you will find a slew of settings that can be adjusted to increase speed.
General:
Drawings → Performance:
Drawings → Display Style:
Colors:
Display:
Performance:
Remember when I said some changes might compromise a bit of functionality? Well, these settings definitely qualify. Verification on rebuild is a feature that helps validate complex geometry, causing geometric errors to become apparent early on in the design process rather than later, but it means extra calculations. Automatically loading components lightweight causes only a subset of model information to be loaded (on an as-needed basis), which speeds things up, but doesn’t always give the results people want. Should you make these selections? How badly do you want to speed things up?
Assemblies:
External References:
FeatureManager:
View:
Search:
You have now optimized SOLIDWORKS for faster performance. Take it for a test drive! If you don’t like some of the settings, you can always change them back. If you can’t remember which ones were which, you can reset them using the Reset button at the bottom of the System Options dialog box (below), or apply the previous settings that you saved before you began (you did save them, right?).
SOLIDWORKS Performance Evaluation Tool: User Guide
7 Ways to Improve SOLIDWORKS Large Assembly & Drawing Performance
SOLIDWORKS PDM 2020 Performance Improvements
SOLIDWORKS Design for Performancee with Patterns
To Thread or Not to Thread? Hyper Threading and SOLIDWORKS Performance
About Gary Ballentine
