SOLIDWORKS Default Templates Error
Article by GoEngineer on Dec 26, 2022
When you create a new document, import a file from another application, or create a derived part in SOLIDWORKS, the default template is used for the new document. However, sometimes if the file paths are not set up correctly, you may get the error message below:
SOLIDWORKS Default Templates Not Valid Warning
“The default templates are not valid. The problems can be resolved by correcting the default templates under the options dialog. Do you want to continue with a blank template?”
Defining the Default Templates
To correct your file path, follow the instructions below:
  • Navigate to Options
  • Under System Options, select Default Templates
  • Browse to the specific template you want by selecting ...
    SOLIDWORKS Default Templates System Options
  • Here, you can select the default template from the “New SOLIDWORKS Document” dialog box and click OK.
    New SOLIDWORKS Document Dialog Box
Note: These SOLIDWORKS templates in the above dialog box are defined by the templates found in the file location(s) listed under Tools > Options > File Locations > Document Templates.
Editor's Note: This article was originally published in May 2017 and has been updated for accuracy and comprehensiveness.
I hope you found this quick tip helpful. Check out more SOLIDWORKS tips and tricks below.
More SOLIDWORKS Tutorials
SOLIDWORKS Warning: A Journal File Could Not Be Created
Fix SOLIDWORKS Resources Running Low
How to Update Templates in SOLIDWORKS
How to Adjust Template Settings in SOLIDWORKS
Using PDM Templates Inside SOLIDWORKS
