Every few releases it’s always a good idea to update your SOLIDWORKS templates to the latest version you and your company are currently using. Being one of the techs on the Technical Support team, we run into the rare occurrence that a part, assembly or drawing seems to have become corrupt. It’s even more rare that we find that multiple files fail to open, this is when we start looking at the templates being the culprit.
With CAD software continually updating, you would not want to design your new parts in old templates. Similarly, would you want to use a template from an old version Microsoft Word 5.5 to be used in your Microsoft Word 2016?
Over many years, during the normal upgrade path of SOLIDWORKS, templates get changed, updated and saved in the current version of SOLIDWORKS. This should allow the users to have templates that are of the best quality to start their new part, assembly and drawing file(s) with. However, as with any program on Windows, templates can have problems. The steps below are how to get a fresh set of current templates created and, if so desired, to copy the Drafting Standard and Sheet Format (title block) over to the new template(s).
Hint: To check the age of a part or assembly template you can, start the new part or assembly, right click over one of the normal planes (Front, Top or Right), select Properties and look at the Date created and Last modify fields.
Here is an example of a template to NOT continue using until it’s updated (replaced):
At this point, you can just keep using the new templates that SOLIDWORKS created, modifying them as needed or you can use these templates as the basis for creating updated version of your old templates. If you plan on updating your old templates, then you may want to add the old paths back into File Locations, Document Templates.
Hint: I like to name my templates as to what they are and when I created them. i.e. ‘Part Inch 2020.prtdot’
Repeat these last steps 1) through 5) for your assembly and drawing templates. For your drawing template, you will also need to move over your Sheet Format (Title block) if you’ve customized them. To move over your Sheet Format follow these general additional steps.
To expand on these steps if you have additional size drawing sheets and/or need to update your title block with extra things like, Annotations that are linked to custom properties.
SOLIDWORKS – Drawing Templates Pt. 1 of 3
SOLIDWORKS – Drawing Templates Pt. 2 of 3
About Michael Nolte
Michael Nolte is a Sr. Applications Engineer at GoEngineer. He has been in the SOLIDWORKS reseller channel since 2007 and is skilled in a large array of SOLIDWORKS products. He has been a Certified SOLIDWORKS Expert (CSWE) since 2011 and received his Dassault Systems Elite Application Engineer status in 2019. Combined with 24+ years of industry experience. Michael specializes in SOLIDWORKS PDM and SOLIDWORKS Electrical and is a Certified SOLIDWORKS Instructor based out of Northern Arizona.
