Saving a SOLIDWORKS File as a PDF vs. Print to PDF
Article by Rodolfo Gutierrez on Aug 31, 2017
File > Save As > (*.pdf) converts your SOLIDWORKS drawing to plain lines then, using proprietary code, saves it to a PDF.
This is a SOLIDWORKS function and is not relying on any third party to publish your PDF.
SOIDWORKS Save as PDF vs Print to PDF
File > Print > (PDF writer) uses the SOLIDWORKS print engine to spool and communicates the information to your selected PDF printing software to produce the PDF.
SOLIDWORKS simply sends the information to the PDF writer or a virtual printer, and therefore the PDF writer is responsible for producing your PDF and not SOLIDWORKS.
SOLIDWORKS Print to PDF
What Does This Mean?
For the examples below, I used CutePDF Writer (free), Adobe Reader DC (free), and SOLIDWORKS 2017 SP 3.0 (not free).
Original
This was cropped from inside of SOLIDWORKS. It has the default drawing sheet paper color.
SOLIDWORKS Save As PDF Example Part
Tip: To change the drawing sheet paper color, simply go to System Options > Colors > Color Scheme Settings > Drawings, Paper Color > Edit.
Save As PDF
Save As PDF SOLIDWORKS Example Part
Options
I used the default Save As PDF options.
SOLIDWORKS Save as PDF Options
Print to PDF
SOLIDWORKS Print to PDF Example
Page Setup
SOLIDWORKS Print to PDF Page Setup
For Scale: Scale to fit
Drawing Color: Color/Grayscale
Orientation: Landscape
The Results
Images
When producing PDFs that have images, it is best to Print to PDF. You don’t want those images being translated to plain lines.
Save as PDF vs Print to PDF SOLIDWORKS Tutorial
You can clearly see the difference when comparing the penguins in both copies. The PDF writer handles images a lot better.
Lines overextending
Printing to PDF is notorious for overextending lines.
Lines Overextending in SOLIDWORK Save As PDF vs Print to PDF
Rebuilding
Most, if not all, automated PDF conversion tasks/macros use the Save As PDF feature. It forces a drawing to rebuild before producing the PDF. In a team environment with automated PDF conversion tasks, often times the PDF copies come out with undesirable changes. If any changes are made to the model(s) after the drawing is finished but before the conversion task kicks on, those changes will show up in the PDF. This has been known to do more harm than good.
SOLIDWORKS PDM
PDM tasks also use the Save As function, which means you are susceptible to the rebuilding step mentioned above.
So, which one is better?
Both methods have their strengths and weaknesses. SOLIDWORKS has improved their internally-written code to produce those PDFs, but a lot of users still lean more on Print to PDF because they think of making PDFs as a printing process.
I’ll leave you with this; Save As PDF is a SOLIDWORKS feature and is supported by them—Print to PDF is not supported because it uses a third party software to create that PDF.
More SOLIDWORKS Tutorials
SOLIDWORKS PDM Professional Office to PDF Conversion Task Installation
How to Update PDF Documents in SOLIDWORKS PDM with a New Revision
Simple Way to Rename SOLIDWORKS Files
Setting Up Shared Weldment Profiles in SOLIDWORKS
Configured Weldment Profiles: SOLIDWORKS Tutorial
VIEW ALL SOLIDWORKS TUTORIALS
About Rodolfo Gutierrez
