When trying to standardize designs, it is a good idea for you and your team to use the same weldment profiles in SOLIDWORKS. This tutorial covers the steps to set up shared weldment profiles.
Let’s assume the weldment profiles everyone will be using moving forward are the ones you are currently using with SOLIDWORKS.
Locate the Weldment Profiles folder by going to Tools > Options > System Options > File Locations > Weldment Profiles.
The default folder location is C:\Program Files\SolidWorks Corp\SolidWorks\lang\english.
Change the weldment profiles location in the System Options to the new shared location and ensure all users are pointed to that location. Be sure to give the users at least read access to the network folder. Hit Yes when being prompted to add that folder path as a search path.
SOLIDWORKS - Weldment Configurations
SOLIDWORKS 2020 Structure Systems for Weldments
Designing a Trailer Using SOLIDWORKS Weldments
About Rodolfo Gutierrez
