SOLIDWORKS Content: Download Additional Routing Libraries
Article by Lauren McGarry on Jul 12, 2021
Installations of SOLIDWORKS include a set of routing components with your Design Library. Additional piping Routing content can be downloaded through SOLIDWORKS Content, including parts and assemblies that align with different Standards like ISO and DIN.
SOLIDWORKS Content Folder Routing Libraries
FIG. 1: The Design Library tab of the Task Pane.
In SOLIDWORKS, select the Design Library tab of your Task Pane. Expand SOLIDWORKS Content > Routing. In the Routing folder, the additional libraries are grouped by Standard.
Each item in the Standard folders links to a .zip file that contains the associated Routing components. To download one of these .zip files, hold the CTRL button on your keyboard and left-click the desired fileset.
Additional Routing Libraries Under SOLIDWORKS Content
FIG. 2: A flyout appears with these instructions when you hover your cursor over one of the items in a folder.
You'll be prompted to select a location for this .zip file. Once you select a folder, the .zip file will begin downloading.
Once the .zip file has been downloaded, browse to it in a Windows File Explorer and extract its contents. Then, move the extracted files to the piping subfolder in your Routing library location. The default location is C:\ProgramData\SOLIDWORKS\SOLIDWORKS 20XX\design library\routing
You can double-check which folder is set to be your Routing library folder by going to Routing File Locations and Settings in the Routing Library Manager.
Accessing the SOLIDWORKS Routing Library Manager
FIG. 3: To open the Routing Library Manager, go to Tools > Routing > Routing Tools > Routing Library Manager.
SOLIDWORKS Routing File Locations Settings
FIG. 4: Go to the Routing File Locations and Settings tab to see your Routing library location.
How you organize your new files in the piping folder will depend on your workflow and where you want these additional parts and assemblies to appear.
One option is to create a new folder in piping for the Standard you just downloaded, then move your downloaded and extracted files there.
SOLIDWORKS ISO Piping Copper Alloy Library Example
FIG. 5: The ISO Piping Copper Alloy library stored in a new folder in piping for ISO components.
Another is to move the extracted files into the existing subfolders in piping. For example, in the downloaded ISO Piping Copper Alloy fileset, there is just one folder containing Flanges. If I don't want my flanges separated by Standard, I can just cut and paste the part files in the ISO Piping Copper Alloy Flanges folder into the flanges folder that already exists in my Routing library folder.
SOLIDWORKS Tutorial Download Additional Routing Libraries
FIG. 6: Moving the contents of the newly downloaded Flanges folder into the pre-existing flanges folder in the Routing library piping location.
Though it is typically not necessary, especially in later releases, you may need to sync your Routing library after moving your new files into place. This article walks through the steps to sync your library: Updating the SOLIDWORKS Routing Database.
I hope you found this article helpful. Check out more SOLIDWORKS tips and tricks below.
Related SOLIDWORKS Tutorials
Why Won't My Wires Route in SOLIDWORKS Electrical Part 1
Why Won't My Wires Route in SOLIDWORKS Electrical Part 2
Quick Clicks in SOLIDWORKS
Last SOLIDWORKS Version Saved in Quick Tip
How to Upgrade SOLIDWORKS to a Newer Version
VIEW ALL SOLIDWORKS TUTORIALS
About Lauren McGarry
