Make Multibody Parts from SOLIDWORKS Assemblies
Article by Zach Brown on Jun 04, 2024
New to SOLIDWORKS 2024 is the ability to make multibody parts from assemblies. While saving an assembly as a part has always existed, a new tool provides additional options. In this guide, we’ll compare the differences between these two methods.
Old Method – Save Assembly as Part
As previously mentioned, an assembly can be saved as a part file using File > Save as, then changing the Save as type to SOLIDWORKS Part.
How to Save a SOLIDWORKS Assembly as a Part in Version 2023 and Earlier
For an in-depth look at this process, check out our article: Save SOLIDWORKS Assembly as Part and Preserve Geometry References.
Pros
The advantage of using save as part is the option to Preserve geometry references. Every face in the assembly has a unique identifier (or name). These unique identifiers are used as references for mates, sketch relations, reference geometry, etc. If the name of a face changes, it can cause errors downstream. The Preserve geometry references option preserves the names of each face when the assembly is saved as a part. If a subassembly is saved as a part and replaced in an upper-level assembly, any references to those faces should remain intact.
Cons
While this method is effective, there is little control over what gets saved. There are only options for saving All components, Exterior faces, or to Include specified components. Furthermore, there is no link between the assembly and the part file. If the assembly is updated, the part will not reflect the changes, so the assembly must be saved as a part again.
New Method – Make Multibody Part
In SOLIDWORKS 2024 and higher, there is a new command called Make Multibody Part. With an assembly open, go to Tools > Make Multibody Part. SOLIDWORKS Make Multibody Part Command New in Version 2024
Make Multibody Part PropertyManager
After clicking Make Multibody Part, the PropertyManager is displayed and provides more options for what gets transferred to the part. You can now include items such as Surface bodies, Axes, Planes, Coordinate systems, and Materials. We can also choose to Break link to the original assembly and under Visual Properties, Propagate from original assembly.
Once all transfer options have been set, click the green check mark to finish the operation. After clicking OK, the part is opened while the original assembly remains open in another window.
Note: The part file is not automatically saved like save as part. You’ll still have to click File > Save to give it a name and choose the destination.
SOLIDWORKS Make Multibody Part PropertyManager
In the multibody part file, a feature is created in the FeatureManager Design Tree labeled Make Multibody Part1, which can be expanded to see a list of folders. A separate folder is created for each transferred entity. Expand each folder to see its contents.
SOLIDWORKS Solid Bodies Folder with Make Multibody Part
The Solid Bodies folder contains individual bodies representing each component in the assembly. Each body is given the same name as the component it was created from. If a material was applied to the component and materials were selected to transfer, the body can be expanded to see the applied material.
Make Multibody Parts from Assemblies SOLIDWORKS 2024 New Command
Just like any other multibody part file, a cut list can be created by clicking the Weldment icon on the Weldment Toolbar.
Weldment Icon on the SOLIDWORKS Weldment Toolbar
Pros
The advantages of using Make Multibody Part are:
  • There are more controls on what can be transferred to the part file.
  • A link can be maintained between the part file and the original assembly. Changes to the assembly will propagate to the multibody part.
Cons
The disadvantages of this method are:
  • There is no option to preserve geometry references like save as part.
  • Currently, there is no way to export multiple configurations of the assembly to the multibody part file. Only the active configuration gets saved as a part.
  • Performing this on other configurations of the assembly creates a new part file.
I hope you found this article explaining the new Make Multibody Part tool in SOLIDWORKS 2024 helpful. Check out more tips and tricks listed below. Additionally, join the GoEngineer Community to participate in the conversation, create forum posts, and answer questions from other SOLIDWORKS users.
SOLIDWORKS CAD Cheat Sheet
More SOLIDWORKS Tutorials
How to Add a Watermark Note in SOLIDWORKS
Getting Started with the SOLIDWORKS Design Library
SOLIDWORKS Fixed vs Floating Components
SOLIDWORKS Trim Entities Command Capabilities
How to Create Text Around a Circle in SOLIDWORKS
VIEW ALL SOLIDWORKS TUTORIALS
About Zach Brown
View all posts by Zach Brown
