A good way to simplify a large assembly is to save it as a part. Doing so will convert the file references into multiple solid (or surface) bodies in the resulting part file’s feature tree. This is a major way to improve performance on large assemblies by using the simplified part versions of sub-assemblies in the upper level.
When creating a model SOLIDWORKS generates a name for each face, called a unique identifier, which the program uses to keep references intact. Saving an assembly as a part creates new unique identifiers for each face when the reference geometry is converted to a part file. As a result, when a sub-assembly is saved as a part, and then replaced in the upper level, it would cause errors to mates referencing the former sub-assembly. In drawings any annotations connected to the former reference geometry would become dangling as well. This usually resulted in a lot of clean up to be done.
Now in SOLIDWORKS 2018 a new option called Preserve Geometry References has been added to the Save As dialog box when saving an assembly as a part file.
1. With your top level assembly open, left click on a sub-assembly that you would like to save as a part and chose Open Subassembly.
2. With the sub-assembly open click File, Save as. Chose the option to Save as when prompted.
3. In the Save As dialog box use the Save as type pull down to change it to Part (.sldprt)
4. In Geometry to save you have three options
5. Finally click the check box for Preserve geometry references and click Save.
6. Switch back to your top level assembly then right click on the sub-assembly, and chose Replace Components.
7. In the Replace property manager chose any instances of the sub-assembly that you want to replace with the part version, or click All Instances. Then browse to the part file you just created.
8. Under Options click the check box for Re-attach mates and click Ok.
9. You will then get a Mated Entities dialog that shows all of the mates are still in tact (referenced by green check marks).
10. Click OK.
This result is you now have all of the sub-assemblies replaced with the simplified part file, and the best part is no mate errors.
If you have a drawing of your top level that included dimensions or other annotations pointing to the sub-assembly, you will notice that the relationships remain intact there as well meaning no dangling dimensions.
Open the part file to see all of the former file references converted to solid, or surface, bodies.
In the case that you need to make changes to the sub-assembly and have the part update in your upper level you will need to do a couple of things to ensure all references stay intact. Essentially we will be reversing the order of operations, then repeating the steps above.
1. In the top level assembly right click on the part file that was your former sub-assembly and chose Replace Components.
2. Browse for the sub-assembly that had been replaced with the part file and make sure Re-attach mates is selected, then click OK.
3. Click Ok again to accept Mated Entities.
4. This will replace the part file with the sub-assembly again and all mate references will still be intact.
5. Make any changes to the sub-assembly and save your work.
6. You may now repeat the steps at the beginning of the document to save as the sub-assembly as a part again and replace it in your top level assembly.
This concludes the tutorial. I hope this was helpful and thank you for visiting the GoEngineer blog.
