Creating a .CVS file: SOLIDWORKS PDM Tutorial
Article by GoEngineer on Sep 01, 2021
What is a Local Vault View?
To access a SOLIDWORKS PDM vault, a user needs to have a local vault view. The local vault view will allow the user to access the files in the vault, check them out and in, transition them through the workflow, and other vault activities.
Creating a local Vault View
A local vault view can be created by running the View Setup Wizard that is installed with the PDM software. The person running the Wizard would need to know the Server name where the SOLIDWORKS PDM vault is hosted and have attached access to this server. If the person running the Wizard is the Admin, this is easy, but in a larger rollout, the admin may not be able to be the one to complete this step. This is where the .CVS file is useful. The .CVS file can be used to create the local vault view from a file that the user can launch from their desktop.
To create the file start by typing the Run from the Start menu and enter this command:
“C:\programs files\solidworks pdm\ViewSetup.exe /a”
Adding the trigger /a will create the file.
Creating a CVS file
The View Setup Wizard will start; follow the steps for creating the vault view.
SOLIDWORKS PDM View Setup Wizard Welcome Screen
Select the server where the vault is hosted.
Select Archive Servers SOLIDWORKS PDM
Select the vault.
Select Vaults SOLIDWORKS PDM
Select the location.
Select the Location Screen SOLIDWORKS PDM
Then click finish.
SOLIDWORKS PDM Review Actions
When finish is selected, the wizard will prompt for a location to save the .CVS file.
Save CVS File SOLIDWORKS PDM Tutorial
The .CVS will be saved and is now ready to use.
CVS File Creation Complete
Using the .CVS file
Now that you have the .CVS file, the end-user can launch it on his machine by double-clicking on the file from the desktop.
Using CVS File in SOLIDWORKS PDM
That will automatically launch the wizard.
Review Actions Screen SOLIDWORKS PDM
The user must select finish, then they will then be prompted to log into the vault. After logging in, the local view will be created.
Create CVS File Vault Loggin
Now that the local vault view is created, and the user can now access the vault.
Create a Local Vault View in SOLIDWORKS PDM
Next, learn how to deploy the CVS file you've made on a client machine in this article.
Note: If you are a GoEngineer customer and have questions concerning this article, please contact our support team.
More SOLIDWORKS PDM Articles
SOLIDWORKS PDM: Create and Deploy a Local View File
SOLIDWORKS PDM Undo Checkout By Other Administrators
Managing SOLIDWORKS PDM Licenses
Customizing SOLIDWORKS PDM Checked Out By Column
