If by some chance, Visualize is already installed on a machine that you want to use as a Boost server you will need to uninstall Visualize, install Boost, and if necessary but not recommended to re-install Visualize.
If terms like...
are not part of your vernacular you should sit down and discuss network rendering with your network admin staff and have them assist. The help files and the following information will be updated and far more detailed with Visualize 2017sp1.0 and forward.
You will need wide open read/write permissions to the computer and registry, Admin rights. The antivirus, firewalls, windows Defender, spyware detectors, etc. will need to be turned off throughout the process. Even for the first connection between the Client machine and the Boost machine.
This connection and setup should stay in place barring any computer location/connection changes.
Don’t be surprised if during this process, even after step #8, you need to run a command line to find an IP address or add an exception to firewalls on either end. You might even see something like an unverifiable certificate.
How to Use the SOLIDWORKS Configurations in Visualize
Installing and Configuring SOLIDWORKS Visualize
SOLIDWORKS Visualize 2020 - What's New
About Randle Wood
