SOLIDWORKS Thumbnail Previews
Article by Randle Wood on Feb 05, 2021
If you have experienced the SOLIDWORKS Open dialog or Windows Explorer dialog not displaying the thumbnail preview picture, there are a few reasons that can cause their loss. In this article, we SOLIDWORKS thumbnail previews and share some solutions to remedy the issue.
#1 SOLIDWORKS System options
Check the SOLIDWORKS System options- Tools > Options > System Options tab > general > Show thumbnail graphics in Windows Explorer.
SOLIDWORKS System Options - General
It should be noted that the files must be opened and saved in SOLIDWORKS to generate the thumbnail.
#2 Check the Windows Folder Options
Check the Windows Folder Options. Two options are needed, one selected and one de-selected.
First, open the Windows Control Panel > File Explorer Options.
Windows Control Panel SOLIDWORKS Thumbnail Preview
This will display the File Options dialog where we will select the View tab.
Secondly, de-select "Always show icons, never thumbnails".
File Explorer Options in SOLIDWORKS
Finally, under the same View tab, scroll down until you find, "Show preview handlers in preview pane" and select.
SOLIDWORKS Thumbnail Preview Solutions
The Apply button in the bottom right corner will no longer be greyed out. Select Apply.
#3 Windows Performance Options
Note: SOLIDWORKS Thumbnails may be disabled if you have customized performance levels set in Windows. Also, if the top radio buttons are set to “Adjust for best performance”, your previews and thumbnails will be disabled.
Start by going to Windows Control Panel > search "Performance" > select "Adjust the appearance and performance of Windows".
Adjust Appearances and Performance of Windows
Select "Show thumbnails instead of icons" and apply as before.
Windows Performance Options for SOLIDWORKS
#4. DLL Registration
SOLIDWORKS installs many .dll files that are required for the program to run properly, interface with the prerequisites and work in the Windows O/S environment. If you install without  full LOCAL Windows Admin permissions  it can prevent the needed registration of the .dll files. With the proper permissions, you can manually register the following .dll files to correct the issue.
  • Swdocumentmgr.dll (by default location - C:\Program Files\Common Files\SOLIDWORKS Shared)
  • Sldthumbnailprovider.dll (by default location - C:\Program Files\SOLIDWORKS Corp\SOLIDWORKS)
To manually register these files, follow the steps below. If you have any questions, please contact your CAD Admin and/or IT team before starting.
  1. Log into Windows with full Local Administrator permissions
  2. Using Windows Explorer, browse to find the .dll files from the previous page (some paths may vary based on O/S).
  3. Open a Command Prompt (CMD) as Administrator.
    DLL Registration SOLIDWORKS Thumbnail Preview
  4. Enter the following text and enter after each
    1. Regsvr32 “C:\Program Files\Common Files\SOLIDWORKS Shared\swdocumentmgr.dll”
    2. Regsvr32 “C:\Program Files\SOLIDWORKS Corp\SOLIDWORKS\sldthumbnailprovider.dll”
SOLIDWORKS Costmetic Thread View Options
How to Copy SOLIDWORKS Custom Properties to Other Files
Customizing Colors in SOLIDWORKS Drawings
Customizing the SOLIDWORKS Hole Callout File
SOLIDWORKS FeatureManager: Hidden/Forgotten Commands
About Randle Wood
View all posts by Randle Wood
